Old 23-07-2009, 02:52 PM   #1
Jarp_W
Thumbs up 2 Lt Escort 4 speed gearbox to 1.6 Lt Motor
Could anyone who knows let me know if you can fit a 2 Lt Escort 4 speed gearbox to 1.6 Lt Motor all MK2? And if you can what if any modifications need to be made?
Also I am looking for a 1.6 Lt MK2 4 speed gearbox if anybody needs to get rid of one.
I live in Northern Victoria.
Thanks
Jarp_W is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2009, 06:58 PM   #2
R0BD0G
R0BD0G's Avatar
yes.. different engine and gearbox mounts?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2009, 07:18 PM   #3
Les
Mk2 Racer
Les's Avatar
I have two spare Mk2 1600 gearboxes and motors, if you can't get anything local I'm in Whyalla SA but no problems sorting freight, just adds cost but if you get stuck just yell
Cheers,
Les
Les is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2009, 10:17 PM   #4
Mk1Bluey
Helping Hand
Yeah it sure will as all bellhousings are the same.. the only difference is make sure when you look inside the bellhousing where the
clutch fork is, there will be a little allen key bolt.
Ensure that if there is a little rectangle spacer that you remove it. This spacer is only used for the 2 litre.
You will need to fit a shorter allen key bolt or grind down the one you pull out.This bolt just holds the fork in place.
If you leave the spacer in the fork will jam hard against the back of the fork opening and you wont get the right clutch throw.
Hope this helps.
Blue.
Mk1Bluey is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2009, 11:55 AM   #5
Jarp_W
Thumbs up 2 Lt Escort 4 speed gearbox to 1.6 Lt Motor. Solved Thanks
Thanks to all you guys that replied. I am an old fart new to online forums so apologies for not responding earlier. I have actually repaired the existing 1600 gearbox (so don't need one for now) it was a sheared selector lever on the rail. Pretty simple fix in the end but I am rapt because I have not got a mechanical bone in my body. Anyway the problem with the 2 L box was exactly as Mk1Bluey described. Thanks Mk1Bluey. Next project will be to put the 2 L box back into a Mk 2 Ghia that someone converted to an auto. God knows what I am going to come up against with that.
