01-08-2009, 10:39 AM | #1 | ||
I have a Samsung 32 inch LCD have had it for about a year now and have nevr been able to play my playstation 3 on HDMI, first they told me it could be the cable so tried another, no luck then I tried the unit on a Panasonic plasma we have and it worked no probs. So I just continued to play it on there for a while. Then i got fed up with it and samsung told me to take it to the repairers so I did and they check all connectors and tested it and it wa fine and told the cable was faulty when I know it wasnt. Got it back and tried it and got nothing once again. Is there anyone out there that knows any tricks to these things or should I ring Samsung again?
Cheers, Tyson
1997 EL GT, #102, Manual, 27000kms. 2002 AU3 TS50 #114, Auto |
01-08-2009, 10:49 AM | #2 | ||
F6 - with sugar on top
I would be taking both the panel and the PS3 to the repairer for them to evaluate the entire setup..
HDMI usually wouldn't have issues like this and if you have tried a few different cables (of varying quality) then I trust you have done pretty much all you can as it works on another panel. Stick it to Samsung, they have 3yr wty for that specific panel if I recall correctly. |
01-08-2009, 11:06 AM | #3 | |||
Long live the GT !
Some are suggesting it could be lack of HDCP compliancy and others think it's just the brand name. My friend bought a brand new 19" Samsung LCD, plugged it into his PS3 with HDMI and it just would not work. He tried 3 different HDMI cables before giving up and buying an LG. Hasn't had a problem since!
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
01-08-2009, 11:21 AM | #4 | ||
Mot Adv-NSW
HDMI version 1.2 or 1.3?
01-08-2009, 11:30 AM | #5 | ||
where do i find that?
01-08-2009, 11:48 PM | #6 | ||
Regular Schmuck
Feels like I've logged onto a Samsung site...
Have you tried all available HDMI ports? Worked fine on my 40" and works fine on my 46" LED Samsung. |
02-08-2009, 02:12 AM | #7 | ||
Fantastic Plastic
Sometimes it can be due to the 'ms' millisecond refresh rate of the lcd, if it's not fast enough (usualy around 8milliseconds '8ms' minimum) then alot of hdmi devices cause drama from my experience, reason I stick to Plasma Tv's !.
02-08-2009, 11:07 AM | #8 | |||
02-08-2009, 11:22 AM | #9 | ||
I have a Samsung 32" LCD and a PS3. No problems here.
02-08-2009, 07:27 PM | #10 | ||
FG XR6T trayback
Does the PS3 work with the AV connectors, rather than the HDMI??
02-08-2009, 10:34 PM | #11 | |||
02-08-2009, 10:37 PM | #12 | ||
Yeah it does, have component cable on it atm. But having played it on HDMI I want it to work
03-08-2009, 01:25 AM | #13 | ||
Gassed XR6
Hey Suttoo,
Go to a Dick Smith Electronics outlet, try a Belkin HDMI cable. At least at DSE you can return the item within 14days and get yur money back if it doesn't work! Belkin works fine on my Samsung 101cm LCD. Cheers. |
04-08-2009, 05:13 PM | #14 | ||
I also have a 32 inch Samsung LCD using a PS3 through HDMI and its pretty much faultless except on the odd occasion the screen will go blank for a couple of seconds. Picture reappears and it might do it again afterwards. It will sometimes do this about 5 times then go back to normal. Not sure what it may be, wondering if anyone else experiences this and is it something that will get worse?
04-08-2009, 06:16 PM | #15 | |||
For instance when I watch TV it it is 1920x1080 but it changes the refresh rate and resolution for a particular game on PS3. 5 times seems a bit odd though. |
