I was just told this evening my brake lights are gone. I can't seem to find where the fuse box is. There is a panel in front of the drivers seat, but I can't get the bloody thing open.
Firstly welcome the forums,
There is a fuse box in the engine bay and there is one behind the dash as well. Did you check if both globes are blown? Do your parkers work? Or even the brake switch behind the pedal fault.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
Knows nothing. Apparently
The one in the engine bay is right up near the windscreen on YOUR right hand side (when facing the front of the car) it's just behind the airbox
the other one is behind the glove box. Empty all your junk out of it, push the sides together and it'll drop down a little more, then unhook the thing that makes the door open slowly, it's like a key hole shaped thing that just unclips. Your glove box should drop right down out of the way. In one of the fuse panels, theres a tiny little yellow pair of tongs. Use that to pull your fuses, not pliers as you'll probably break a fuse. And you'll bust your nails trying to do it with your fingers. Uhh.... not that I worry about that sort of thing..... :S
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! ![]() 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
