Old 28-11-2009, 11:20 AM   #1
TK-421
Default What E series suspension will fit an AU 1?
I see sellers on ebay list thier rear shocks and springs to fit EA to AU 1 non irs, what about the front springs are they the same?
samething applies to exhaust systems being sold on ebay, to fit ea to au 1 non irs. Will any of these parts fit an AU1?
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2009, 11:43 AM   #2
bodes-sh
exhaust and rear springs will suit sedans, but not fronts
Old 28-11-2009, 05:20 PM   #3
White_sr_taxi
would that almost apply to series two sedans as well? the live axle varents?
White_sr_taxi is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2009, 08:01 PM   #4
T3man
T3man's Avatar
Rear shocks and springs for E-Series through AUIII are interchangeable. That is not to say that the result of swapping them will be what you might want. Spring rates and shock rates will vary between model and series. However aftermarket items will generally be "one size fits all" in approach.
Old 24-12-2009, 10:02 AM   #5
munchkin323
AU XR6
munchkin323's Avatar
I thought that the IRS models (series II and III) were a different set up to the non IRS modesl (series I), and therefore springs were not interchangable between the models. Ebay sell springs for AU non IRS and AU IRS...
munchkin323 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2009, 11:37 AM   #6
blownv8au
Pro Street Au Ute
blownv8au's Avatar
not all au 2 and 3 had irs. this is about non irs suspension because ea-el never had it and if you poke you head under any live axle falcon from 82 to 02 they basically look the same thats why some of the parts are interchangeable.
Old 24-12-2009, 12:01 PM   #7
T3man
T3man's Avatar
You thought right - but has nothing to do with the topic of the thread.
However, your inference that Series I were all non-IRS and Series II and II were all IRS is incorrect.
Old 24-12-2009, 12:07 PM   #8
MAD
Petro-sexual
MAD's Avatar
Live-axle rear shocks are actually interchangeable from XE-AU
- The Story
Old 24-12-2009, 12:57 PM   #9
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
i heart my live rear axle
Old 24-12-2009, 01:45 PM   #10
White_sr_taxi
very good for towing and less likely to stuff up. is it simmilar to the ute and wagon rear? beside the suspension obvsiously?
Old 24-12-2009, 02:11 PM   #11
T3man
T3man's Avatar
They will physically fit BUT they are very different in valving - you would be very illadvised to fit X-series shocks onto E-Series or later. Unless you opted for the XE ESP shocks. Likewise, E-Series are not as robust as AU. However you could safely fit the AU gas shocks to earlier models and not have any issues.
Old 24-12-2009, 06:37 PM   #12
MAD
Petro-sexual
MAD's Avatar
Yeah, you wouldnt use stock items. But Koni have the same part number for them.
- The Story
