Old 18-08-2008, 02:54 PM   #31
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Cheers. Thanks for that. Already a member so here we go....
http://www.aufalcon.com/cgi-bin/inde...ultimedia&f=40
To get it to work for me I had to go to the above link, save the avi file then it would play in Windows Media Player.
Col.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 08:33 PM   #32
sneaky
sneaky's Avatar
bah, sound file not working for me for some reason. the file is only 70kb when downloaded.
is it working for other people?
i'm in the market for an exhaust, something sporty but not droney as the car spends a lot of time highway cruising (and 6cyl autos usually sound crap with droney exhausts)
-tim
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2008, 07:42 AM   #33
Dauphin
Irregular member
Dauphin's Avatar
-tim
It worked for me. It could be that your internet browser might not know what to do with an AVI file. Try visiting the file and then seeing the direct URL and saving it to your hard drive, then play it back that way.
Old 20-08-2008, 05:13 PM   #34
CYCO TROOPS
CYCO4D Wagon.
CYCO TROOPS's Avatar
I got extractors, hi-flo cat and a 2.25" exhaust. I would like mine to sound louder, but its loud enough to set off alarms (tested) hehehehe.
I'll have a look whats under mine on friday and explain the layout to you cos it'll be at the exhuast place up on the hoist.
www.aufalcon.com.au/cyco4d
CYCO TROOPS is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2010, 01:06 PM   #35
xrford
WAGONE
xrford's Avatar
Once you fit pacies what do you do with the cat cos the stock one is now too long to go in between, needs a straight one without the bend that used to go up to the standard manifold...
Do they make aftermarket ones that just bolt in and is it worth going for a hi flow one on a vct?
xrford is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2010, 02:54 PM   #36
frd906
you can buy the smaller standerd cats and modify it, or just go to a exhuast mob and tell them to mod it to fit
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2010, 03:49 PM   #37
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
i run pacemaker PH 4499's Balistic Hi flow cat and a redback 2.5ich from there with rear resy removed and it sounds nice
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
