Old 03-09-2005, 05:47 PM   #1
BuuBox
Default After a bloody good run, troubles with the car...!
So I've been fixing all the issues with my car over the last few months, and it was all going very well, until I ran into some drama's last night... But first, some back story
On Thursday I changed all the bearings at the front of the engine, for the fan, the air conditioning pulley and the alternator bearings. The alternator was a pain in the ***, stupid Mitsubishi, but other than that it went fairly well. Made a huge difference in noise too, now nice and quiet.
But I went to start it last night, and it just wouldn't. It'd fire, then die. After some thottle massaging (ie full thottle) I could get it started, but jesus the smoke. It seemed to be black smoke, so fuel, and a hell of a lot of it too. I took it for a run, and it seemed to sort itself out, no more plumes of smoke, and it was running nicely, idling as normal.
This morning I tried to fire it up again. Same thing, would fire, then strait away die. I got it started with the same method, but this time with no real smoke. I thought it might be the ECU sorting itself out after being reset, but surely 100km trip would be enough?
Any ideas?
Just one last question... seem to have a weird (maybe) electrical issue at times. Its happen twice when I've been driving along at 100km/h or so, and the car starts surging, and then the tacho drops to 0rpm, despite the fact that it's obviously doing a little more than that. It then goes back up to 1800rpm or so, and sorts itself out.
Again, any ideas?
On a more positive note, I did a service on the auto trans, and was pleasantly surprised when it wasn't too burnt, and there was not a hint of metal on the magnets. Despite this, the shift did seem to improve slightly. Also welded all my exhaust leaks, and put in a new thermostat. Been running very nicely, except for the issues above.
Only a few more things to fix/replace, including:
1. Oil Leak
2. Front Wheel Bearings
3. Flush the heater core
4. Cut and Polish!
Thanks! Much apreciated.
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2005, 01:11 PM   #2
atec77
Cool
Any ideas?
Again, any ideas?
1. Oil Leak
4. Cut and Polish!
look behind the battery under the fill bottle , you should see some relays , replace the black one with one from the wreckers for about $5.00 as this drives most of the fuel systems and lots of other good stuff ( bad relay nothing works), should make it start and the cooling fans will run for 3 seconds after switching the ignition which indicates the relay is fine, now if its still black smoky you may have a faulty fuel preasure reg
good luck
