Old 17-03-2010, 07:03 PM   #1
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Default How to seal heater pipe on back of water pump??
Any tips on getting a good seal on the heater pipe on the back of the water pump? I got a new o-ring, lubed it with rubber grease, cleaned up the water pump and pipe really well, but it's still not a good seal, sometimes it drips (but you never see it). If I put a slight sideways pressure on the pipe connection, then I see it drip, so I guess it drips when going over a bump or something. At least the similar seal at the thermostat housing has got a clip that holds it in reasonably tight -the seal at the water pump has got nothing, just the bolt way back at the back the motor. Or am I missing a mounting bolt underneath the heat shield? Haven't taken the heatshield off to find out.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2010, 09:03 PM   #2
mik
mik's Avatar
when i put a new water pump on mine i put smear of silastic on the seal and pump(just to make sure) and never had any trouble, sorry i can`t remember about the mounting bolt/s for the pipe, if you pull it off again ..........have a very close look at the seal it may be damaged, perhaps the seal is faulty or maybe you nicked it on installation.
Old 17-03-2010, 11:28 PM   #3
AMB
Thanks for your reply mik. Yeh, I had no problem with my daily EF when putting a new pump in. The heater pipe stays where it is, and I just used some rubber grease on the o-ring and it hasn't leaked a drop in 18 months. But with this AU (my wife's car), I wasn't replacing the pump, just the o-ring had perished. To pull the heater pipe out I had to undo the bolt at the back of the motor, and the pipe doesn't go back in straight and easy, to get it in you have to angle it a bit, maybe I did nick the o-ring (but I don't think so), or maybe the seat is a bit corroded (its probably the original pump). May have to try some silastic to help the o-ring seal. I've got a tube of permatex blue, that should be good enough for this application don't you think?
Old 18-03-2010, 08:07 AM   #4
mik
mik's Avatar
that should do the job i think, cheers mate.
Old 18-03-2010, 08:26 AM   #5
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
I have au 6 and it has a bracket and bolt that holds it in place .
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 08:31 AM   #6
JK EX CHASER
Formally kotevski22
I just checked and it is under 2 and 3 spark plugs.
Old 18-03-2010, 08:55 AM   #7
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
there is 2 different size holes in the back of the pumps check with the old pump we had the same problen untill we worked it out
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2010, 09:34 PM   #8
AMB
All fixed, thanks for the help guys. The bracket under the heat shield was missing the bolt (previous owner no doubt -he had also done up the bolts on the front sway bar way too tight to compensate for the worn rubber bushes, which threw the steering and handling way out. $20 worth of new rubbers properly adjusted and its now handling like a new car!)
