Old 03-04-2010, 06:20 PM   #31
XR Martin
XR Martin's Avatar
Probably related to sub zero environments, something LPG has always has trouble with.
2004 BA wagon RTV project.
Old 03-04-2010, 07:36 PM   #32
PoweredByCNG
PoweredByCNG's Avatar
With Liquid LPG, the opposite is true about temperatures. The systems work great in the cold as they do not require coolant to expand the fuel prior to metering into the engine. In hot temperatures, people have reported slow refuelling times and lower than expected usable tank capacity. There's also the issue of purging the system to eliminate vapour 'bubbles' forming in the system prior to the injectors.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there.
PoweredByCNG is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 07:40 PM   #33
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by jpd80
2) Holden's LPG system is not the same as Ford's old mixer thing,
pretty sure the dual fuel already complies with at least Euro IV.
by switching between petrol and electric as needed, Holden might
overcome some of the hurdles Falcon E GAS is now facing for compliance.
It makes me think that Holden looked at dedicated LPG and saw it was too hard,
Ford on the other hand probably felt they could simply solve the problems...
Holdens LPG V6 is still the old 3.6 Alloytec, not SIDI, so its not Euro 4.
Old 03-04-2010, 07:46 PM   #34
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by Fairlane
Christ what is with Ford, it seriously is not that hard for a full sized auto manufacturer to shove decent LPG in their top selling car.
Aftermarket has been able to do it for the best part of two years and fomoco Australia cant do with their hundreds of engineers and full test facilities :
But Ford are doing something aftermarket LPG makers haven't done, make a single fuel LPG engine that runs solely on LPG, not starting on petrol and switching to LPG when its ready.
They are in unchartered territory.
Better off getting any potential reliability problems sorted now rather than later on when they could end up with a stack of warranty claims. Same thing happened with the BA E Gas motors that had to have the stronger rods fitted to prevent them bending after a backfire, something that happened quite a bit in early testing. Maybe this time they did not have the luxury of time to fix whatever problems they may have because it was only picked up late in the program.
Old 03-04-2010, 08:20 PM   #35
PoweredByCNG
The Alloytec in its standard form will comply with Euro 4 easier than any direct-injected engine...
Old 03-04-2010, 09:09 PM   #36
Bossxr8
Peter Car
Bossxr8's Avatar
In terms of particle emissions then yes, but in other forms no. You can't say an engine that uses something like 1.3 L of petrol less per 100 km than a previous engine would be harder to get emissions compliant, it just requires a bit of extra work to make sure particle emissions are ok. Its simple science that for every extra litre of petrol you burn you get a corresponding increase in emissions out the tailpipe. And GM have already done the R&D on SIDI considering its already used both the 3.0 and 3.6 DI engines in the US. Wouldn't have been too hard for Holden to get it to pass Euro 4 as the engine was designed in the US to surpass those levels already, something the old 3.6 doesn't have.
I'd say its a simple case for Holden of not selling enough of them to justify getting it Euro 4 compliant, considering its the only model that uses the old 3.6. Just like the Territory Turbo come July.
Old 03-04-2010, 09:21 PM   #37
jpd80
jpd80's Avatar
Pretty sure that Holden were crowing back in 2008 that the Alloytec already complied to Euro 6,
something to do with corporate engine and US Tier 2 Bin 5 Emission for petrol already being
tougher than Europe's standards...
Here you go from Holden themselves in October 2008:
LINK
The upgraded all-alloy V6 engine reduces noxious tailpipe emissions* assisting petrol Commodore Omega and Berlina variants achieve the highest Green Vehicle Guide noxious emissions score possible (8.5 points out of 10), excluding electric vehicles.
The noxious emission levels meet Euro VI certification, a standard which does not come into effect in Europe until 2014.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:16 PM   #38
PoweredByCNG
That's simply not true.
Fuel consumption only has a direct correlation with CARBON DIOXIDE emissions and that's it.
Leaner air/fuel mixtures (i.e. excess of air), as used in direct injection engines, result in a significant increase in Nitrogen Oxide (NOx) emissions compared to engines running at stoichiometry. Since three-way catalytic converters are only efficient at neutralising NOx when there is no oxygen present in the exhaust stream, it is much more difficult to make a 'lean-burn' engine comply with NOx limits.
The other issue with lean operation is that hydrocarbon (HC - unburned fuel) emissions are higher because the engine runs close to misfire. HC emissions are reliant on the state of the ignition system and catalytic treatment.
Old 03-04-2010, 10:30 PM   #39
CAMS290
trying to get a leg over
CAMS290's Avatar
I heard that this and something to do with the new plastic inlet manifold was causing some grief.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 10:31 PM   #40
PoweredByCNG
Originally Posted by CAMS290
...and something to do with the new plastic inlet manifold was causing some grief.
If the plastic manifolds are a problem, Orbital wouldn't be selling their FG dual fuel kits to the aftermarket!
Old 03-04-2010, 10:44 PM   #41
jpd80
jpd80's Avatar
Could it be that Ford is trying to bundle production line changes to suit itself?
Thinking the new Territory arrives then, I thought about the possibilities:
- eliminate all 4-speed autos from Falcon/Terry at one time
- change over all LPG and trans package at same time
- possibly drop BF 4.0 and make FG engine common across range?
I remember Burela said something in an article last year about bundling changes...
Government looking to bring forward Euro 5 and 6, maybe they triggered this?
Old 04-04-2010, 06:43 PM   #42
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Lean burn does not happen on our SIDO cars at the momment in australia.
It happens overseas, but the cars that doe it have nox convertors in the exhaust systems, sort of like a cat convertor to eliminate the excess nox. The nox convertors will not work on our cars because of the sulphur content in our fuel, this sulphur will stop the nox convertor operating.
The gov has not stood up to the fuel companies and demand change at this point of time. If the sulphur was reduced we could start to get proper lean burn engines.
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2010, 07:39 PM   #43
jpd80
jpd80's Avatar
I has less to do with lean/rich and more to do with droplet size, high pressure direct injection
is able to spray much finer mist with smaller droplet size for better mixing. The result is
more power and better fuel economy depending on how the engine is tuned.
Old 04-04-2010, 07:53 PM   #44
XR Martin
XR Martin's Avatar
Apparently oil sludging is becoming a big problem with DI engines, as the fuel is injected directly into the cylinders, it isnt washing the oil residue from the back of the intake valves.
Old 04-04-2010, 08:55 PM   #45
prydey
Rob
prydey's Avatar
the LI lpg engine isn't direct injection.
as mentioned earlier, what ford are doing different to the aftermarket is making a dedicated (single fuel) liquid injection system. from what i gather from snippets of info from blownba and others, there are rules relating to 'purging' of the lines with engine not running?? obviously this is why the dual fuel applications start on petrol and flick over to lpg at a set point.
putting 2 and 2 together, personally i think the delay is something to do with this.
prydey is online now   Reply With Quote Multi-Quote with this Post
Old 05-04-2010, 10:34 PM   #46
Bobman
Regulator
Bobman's Avatar
Anyone know if the LPi systems will be across the range or only G6 - XR6?
Shame about the delay!
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
