Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Mid North Coast Ford Owners Club
Old 26-08-2010, 02:24 PM   #1
Rural 351
1000+ passes
Rural 351's Avatar
Default 408 cleveland anyone?
I ran my ute at WSID on wednesday 25/8/10, the motor in it is a 408 cleveland built for a mates detomaso, a prolect that is now not going to be completed, It ran in my XY ute weighing 1620kgs 11.7 at 116mph with a full exhaust, pump gas, toploader, and slicks.
If anyone is in the market for a good cleveland its forsale for $8000 complete with carbie, dist, the lot, I will take it to the drags run it and pull it out so you now how it goes, heres a quick run down of it
*Scat 4 inch crank balanced with mallory metal ( takes zero balance flywheel or flex plate )
*Steel 6 inch rods
*Forged flat top 1.2 pin height pistons
*zero deck
*Cast 2V open chamber heads good valves, springs, guide plates, rollers,ect
*Crow solid 246/256 cam
*Weiand accelerator manifold
*850 DP holley
*Ford electronic dist
*Romac balancer
This motor has only done about 100klm plus 3 passes down the strip, Its a pretty good buy for $8000 as a complete going engine compared to those ebay short motors for $8400
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2010, 02:58 PM   #2
djrice
the burgerman
djrice's Avatar
Default nice
dam mate wish this motor was around last year what a beasst did u build a custom crossmemeber for it.how much mods to fit in eb what box does it run
looks good for 8gsss
djrice is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2010, 10:08 PM   #3
mickyyyy
Thats a good deal
My mate called me today asking if i knew anyone that wanted a 393ci with 4v's that ran 10.9 in a XY for 10k, engine is built by CV and just had a freshen up so its ready to rumble.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2010, 12:34 PM   #4
Rural 351
1000+ passes
Rural 351's Avatar
Originally Posted by mickyyyy
Thats a good deal
Yeh these strokers are pretty easy to get into the 10s in a full bodyed falcon, This one was built for a sports car not a drag car, Its all new just ran the cam in then fitted the inner valve springs and took it to the drags it ran real clean with 28 deg total advance and short shifting it at 6000rpm so theres room for improvement, If I was going to have it I would put a bigger cam in it and a high rise manifold, after saying that im sure theres more in it with the existing cam and manifold combo, Not many new engines run there best time first meeting
Old 29-08-2010, 05:09 PM   #5
bcr2734
Off tap Truckie
bcr2734's Avatar
nice useable cam you got there, well done.
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
: Another Power Installment Soon :
1968 KC Bedford
1970 Mk1 Escort GT
1980 Mack Superliner 120t: Project Puppy Dog!
AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5
bcr2734 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2010, 09:22 AM   #6
Rural 351
1000+ passes
Rural 351's Avatar
Default Photo
Old 30-08-2010, 09:32 AM   #7
Rural 351
1000+ passes
Rural 351's Avatar
Default real streetable
Yeh the cam is abit like the crane F246 that every one uses, It was the choice for the Detomaso not what I wanted but now ive driven it I guess its OK, Im a bit old school and want to here the engine rev its guts out im not used to shifting at 6000rpm but I think the syncos are enjoying it
Old 30-08-2010, 04:33 PM   #8
mickyyyy
I'll send a txt to my mates and see if anyone is keen and ill get them to jump on here.
Who machined, assemble and balanced this engine???
Old 30-08-2010, 05:34 PM   #9
Rural 351
1000+ passes
Rural 351's Avatar
C&B performance engines did the machine work and balancing I chucked it together
Old 30-08-2010, 08:58 PM   #10
peachey80
Nothing stays standard !!
peachey80's Avatar
Hey mate,
Looks like your XY is pretty well setup for the drags - looking at your sig a 351 stroke cast 2v head doing an 11.5.....
SHHHHHHH, Quiet, I'm hunting Lions !
Project Car : XA Coupe : XA Project
peachey80 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2010, 07:09 AM   #11
Rural 351
1000+ passes
Rural 351's Avatar
Default Stocks the way to go
Originally Posted by peachey80
Hey mate,
Thanks I enjoy keeping as much stock stuff as I can, Ive been drag racing clevelands since the mid 80s after all that time I should be going faster, As far as being well set up in the body department its stock springs and all, hasnt even got tramp rods just 90/10s
Old 18-11-2010, 07:56 PM   #12
killerjoolz
KillerXR8
killerjoolz's Avatar
and gee the ute purrs along nice now too Bruce.....
FULL X-FORCE STAINLESS EXHAUST,HERROD HP CAMS,YELLA TERRA PLENUM,
GT 500 TWIN 60MM THROTTLE BODY,GT AIRBOX,K&N FILTER,ZF TUNE,CUSTOM TUNE,8" BOSTON ACCOUSTIC SUB,SONY AMP,AUTO METER D-PIC GAUGE,INNOVATE WIDEBAND AFR GAUGE,CUSTOM GAUGE HOLDER FROM STAV AT STINGRAY,
KINGS SUPER LOWS,20 x 8 FPV DARK ARGENT REPLICA'S,BLACK TINT,CUSTOM MATT BLACK DECALS
2009 TWEEKD FG XR8 IN SILHOUETTE
all mods done by Walter Markham from Oztek Performance
killerjoolz is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 05:33 PM   #13
Rural 351
1000+ passes
Rural 351's Avatar
Default ssshhh
Dont know what your talking about
