Old 19-02-2011, 07:09 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Daytime Running Lights in NSW Yes/No ???
Does anyone know the 2011 use of Daytime Running Lights in NSW?
I have found lots of conflicting stuff on the web. Looking to do a 'mod' on my AU
UK
Old 19-02-2011, 07:12 PM   #2
Jim Goose
Lots of cars come from factory with daytime running lights...
The only issue is Fog lights/ spot lights
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 07:13 PM   #3
Uncle_Ken
Uncle_Ken's Avatar
I've heard that current model holdens have been 'booked' for having them on.
UK
Old 19-02-2011, 07:15 PM   #4
Jim Goose
Most probably urban myth... or the owners are too stupid to fight it in court.
If the car meets the ADR then there is no issue.
The state cant overrule the Fed...
Old 19-02-2011, 07:28 PM   #5
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
ADR76 covers the light specifications for DRL's.
ADR13 covers the installation requirements on vehicles. basically 250mm to 1500mm from the ground, and not less than 600mm distance between lamps. Also they are only to be on whenever the ignition is ON, and the vehicle lighting is OFF. Seen a number of HSV's with the DRL's on when the headlights are also on, that is illegal per ADR13.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 07:29 PM   #6
flappist
Please explain how this applies to the cars that were factory fitted with hand held mobile phones and/or radar detectors.
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 07:30 PM   #7
Rodp
Regular Schmuck
Rodp's Avatar
I'd find that unlikely since, as is my understanding, you can't turn them off.
Rodp is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 07:31 PM   #8
Silver Ghia
UK
Probably because they dont comply with the ADR's. See my earlier post.
Old 19-02-2011, 07:39 PM   #9
Uncle_Ken
Uncle_Ken's Avatar
I was thinking about this style
but are these legal in NSW (say mounted to show the raditor)
or as DRL's
UK
Old 19-02-2011, 07:48 PM   #10
Jim Goose
Blue lights are illegal..... in any form.
Old 19-02-2011, 07:51 PM   #11
Uncle_Ken
Uncle_Ken's Avatar
Yes just found at http://www.comlaw.gov.au/Details/F2006L02306
Australian Design Rule 76/00 - Daytime Running Lamps
9. COLOUR OF LIGHT
The colour of the light shall be white. It shall be measured by using a source of light at a colour temperature of 2856 degrees K (corresponding to illuminant A of the International Commission on Illumination (CIE). However, for lamps equipped with non-replaceable light sources (filament lamps and other), the colorimetric characteristics should be verified with the light sources present in the lamp, in accordance with paragraph 10.2 of this Regulation. The colour must be within the limits of the trichromatic co-ordinates prescribed in annex 4 to this Regulation.
Old 19-02-2011, 07:59 PM   #12
Jim Goose
ADR76 as you pointed out allows for daytime running lights... If fitted at the factory in accordance with the ADR then it meets the requirement.
Volvo have have daytime running lights on its models since what? 1975?
And they have been sold here with the lights connected directly to the ignition legally since then.
Old 19-02-2011, 10:19 PM   #13
Keepleft
Mot Adv-NSW
Keepleft's Avatar
Volvo Australia had, in fact, disconnected the DRL's on all models years ago owing the lack of an ADR. When AUS played catch-up and adopted the UNECE rule, they began fitment again.
DRL's, including the regulations later adopted as ECE, then UNECE - were a Scandanavian thing. EU's ECE mandated them for that market not that long ago.
The new LX Mondeo doesn't get the LED DRL's, Zetec does, but no front fogs, Titanium has the DRL and front fogs! Thought Ford would have standardized them through the Mondeo range.
Not that I really care, happy to live without them.
http://www.dadrl.org.uk/
EDIT - Bloody Ipads, had to use computer to fix.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf
Keepleft is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2011, 12:24 PM   #14
Uncle_Ken
Uncle_Ken's Avatar
Default Re: Fog Lights in NSW
Hi all
I have seen these fog lights on ebay..
http://cgi.ebay.com.au/7-COLOR-PILOT...item56416be6a4
Now if the glob is white, and if I get white angel eyes are these legal in NSW?
The reflector is blue.
UK
Old 26-03-2011, 02:43 PM   #15
Keepleft
Mot Adv-NSW
Keepleft's Avatar
Default Re: Daytime Running Lights in NSW Yes/No ???
Can't see any conformity markings on the lens, wattage insofar a halogen front fog light is proper, but we can't tell the beam pattern to accurately determine it's real function, that of a front fog light, or a driving lamp.
You are reliant on the advertising.
The blue lens simply gives a whiter light within the beams range, width/reach.
See Narva/Hella et al for dedicated LED or incandescent bulb DRL kits. I'd be more inclined to fit a rear fog, but that's me:-)
