12-09-2011, 06:05 PM | #1 | ||
Hi all. I have an issue with a grinding noise and rumbling feeling coming through the power steering. I have tried getting the air out of the power steering lines but it is still there. It appears to be at the firewall where the steering column goes through. In the engine bay where it goes through is some type of grommet that appears to have come out of the firewall. But I am having trouble trying to get it back in. I've tried pushing, screwing etc but no luck. Any suggestions? Thanks
12-09-2011, 08:48 PM | #2 | ||
Bugger!
What car mate?
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
12-09-2011, 09:42 PM | #3 | ||
2001 Au
12-09-2011, 09:52 PM | #4 | ||
Bugger!
It's usually a press fit, you'll probably have to pull the column out, at the bottom of it is a bearing, better inspect that. If the grumbling's only when you turn the wheel, it could be that bearing. Which would also explain why it's pushed out!
Also worth jacking the car up, turning the steering by hand and having a listen to the rack, and push/pull on the rack and tie rods to see if you can find any movement there.
13-09-2011, 06:30 AM | #5 | ||
Thanks MongrelEF. The noise appears to be at the firewall. As the steering is turned it is rubbing against this grommet (?). Now that the grommet has come out of the firewall it turns with the steering and the grinding noise and rumbling feeling has stopped. Maybe it's best to leave the grommet out of the firewall?
13-09-2011, 04:30 PM | #6 | ||
Tighten the bolts on your steering rack, your steering rack is loose.
Ford had a product recall years ago like in 05 I took my 00 AUII in and apparently they welded the bolts on the steering rack right? hahahaha imagine what a good welding job they did? Because it was only after that I got the grinding noise! I got under there after checking everything else and just couldn't figure it out and put a spanner on the rack bolts and low and behold they had a lot of tightening to do. Ever since no noise but I seriously wonder if this somehow has put the front end out of whack. Because they wont do a wheel alignment because they want camber castor kit? Its probably the damn steering rack! Everyone who gets camber castor kits has probably got a moved steering rack. Its all a scam I tell you. |
13-09-2011, 06:53 PM | #7 | ||
Bugger!
Yeah, the loose steering rack is a known fault from the EA-AU Falcons. Same goes for the camber kits; they did not use long enough bolts at the factory to allow for future adjustment. Replacement kits have much longer bolts allowing more movement to adjust for component wear.
15-09-2011, 04:30 PM | #8 | ||
how did you go ?
15-09-2011, 04:52 PM | #9 | ||
I'll be looking at the issue tomorrow. The grinding noise and rumble are back so will be looking at the steering rack. Will let you know.
19-09-2011, 12:34 AM | #10 | ||
19-09-2011, 03:23 PM | #11 | ||
Sorry guys, was waiting for the loan of a trolley jack (must buy one). Nope not the steering rack. I'm back to the grommet(?) at the firewall again. If I moved this towards the engine bay, away from the firewall, the noise stop. But it works its way back. I have tried to screw/push it back in, but it is difficult to get at and apply pressure. To replace will mean pulling out the steering column. Might just have to put up with the rumble/noise.
19-09-2011, 05:20 PM | #12 | ||
tried spraying a bit of wd 40 or a smear of rubber grease on the grommet?
19-09-2011, 07:42 PM | #13 | ||
Nope. It seems to be catching on something at the firewall side. I've tried fingers to push, using an open ended spanner to get over the column and push both side of the grommet, but no luck.
