Old 21-09-2011, 07:26 PM   #1
V8XTasy
Default help please with SCT S3 flasher
hi,
I've just managed to pick up an SCT 3000AU flasher from a mate who used it on his turbo BA, but since returned it back to stock and sold it. He didn't use the SCT for anything other than flashing a custom file he had, so doesn't really know much about it.
The instructions for it bare little resemblance to what I see in the menus. It does say that when you select custom tune, you can edit various parameters such as rpm cut off, fueling, idle, ignition advance etc. In reality, it doesn't appear to let you do any of this and the only option is to flash my car (5.4 V8 3v) with one of the custom tunes already in the device (for the turbo). I was hoping at least to be able to get my current tune and edit simple things like idle, but there's no option to do this even.
Has anyone had any experience with these things? Can the SCT only programme a previously supplied custom file and nothing to do with editing a current tune?
Thanks for any help
Falcon BA XT 5.4 V8 3v
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2011, 07:30 PM   #2
Fireblade
Wizard Member
Fireblade's Avatar
Default Re: help please with SCT S3 flasher
Need to take it to a Tuner and get the unit unlocked to your cars VIN number and get a custom tune, can't do it any other way, the unit is useless to you as it sits currently without going to a tuner.
Frosty and FPR - Bathurst winners 2013
Fireblade is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2011, 08:36 PM   #3
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
It will copy your current tune as the factory tune when you upload a tune into the ecu, assuming it has been unlocked by the previous owner.
The problem is you need a tune to suit your car on the x3 before you can use it.
Assuming you had a tune to load, you can not make changes to the tune which will be stored as your factory tune.
You will only be able to make adjustments to any of the other tunes which have been loaded into the unit as long as the person who has loaded them has enabled end user options, if they have not, then no adjustments will be accessible
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
