Old 25-09-2011, 03:48 AM   #61
Bobman
Regulator
Bobman's Avatar
Default Re: VE 6 cylinder hush up?
Yet some people here support a V6 in the Falcon? They're mostly terrible motors and these sorts of issues are common on V6 engines across many brands.
I6 is the king of the six cylinder range. No ifs or buts.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 09:30 AM   #62
stevz
Exclamation Re: VE 6 cylinder hush up?
Originally Posted by 1TUFFUTE
i read somewhere a while ago that the holden commadore is the most recalled car model per sale in aus motoring history. think it was in the racq magazine
Recalls are only done for safety related issues and are completely irrelevant to what is being discussed here.
stevz is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 10:26 AM   #63
jpd80
jpd80's Avatar
Unlike the 4.0 I-6 that can't put away the SV6 in acceleration tests, a 3.7 Port injected Ford V6 would....
No ifs, no buts....
And don't even start on the turbo I-6, the Ecoboost V6 has that more than covered...
A truck version of the EB V6 that makes its (regulated) power on 91 ULP is a generation in front..
270 Kw/ 525 nm versus 270 Kw/ 565 nm....you be the judge....
Looking to the future, the Aussie dollar is already slipping back under parity and if this trend continues,
a litre of fuel will soar which means that six cylinder buyers will be looking for something else to buy.
A smart move by Ford to introduce EcoLPI and Ecoboost I-4 right when petrol prices take off....
I wonder what Holden will do.....they have nothing in the cupboard to go with Ford except dodgy dual fuel V6....
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 11:37 AM   #64
Bucknaked
Bucknaked's Avatar
Originally Posted by Sundeep
80,000km 1 year old Caprice SIDI V6 drank almost 2L of oil between services. Dealer said that it's "common" for them to do that. Really? 2L? It's ok though, they know about it - so it's got a 6.7L sump on it. Lol.
Have a engine light coming on sometimes too, Holden dealer just clears the code and gives the car back. Will make sure I pay more attention as to what code it is next time.
Still love the car though. It's great.
Boss engines were not immune to this. Oil consumption. This is from new.
Old 25-09-2011, 12:22 PM   #65
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
Originally Posted by Bossxr8
Timing belts are more likely to snap than timing chains, and chains don't need to be changed at a particular service interval, they usually last as long as the engine does, so I don't see how you think they are better.
I understand all of this, but when you look at the trouble some manufacturers have had with timing chains over the years. Mitsubishi Sigma's would go through timing chains every 80 to 100k, EA Falcons had heaps of problems with timing chains,tensioners and guides, BA V8's had all sorts of timing tensioner and guide problems, Now the VE commodore is having regular problems. Any car that gets high km's say 400,000 will need a timing chain before the engine needs a rebuild. Falcons get real noisy chains at about 250,000kms, I have owned them, replaced them and heard other cars with them. I have first hand seen Falcon timing chains snap with over 250,000kms. I have not heard of any Timing belts that have had this sort of regular problems in a particular model, but this is probably because they are replaced every 100,000kms and never see 250,000kms like chains. Ducati Motor cycles all run belts as they are very quick to change (about 1 hr compared to 4hrs for a chain) and the belts dont seam to stretch so cam timing stays more constant. There is definately a place for both but if they get chains wrong it get be a very big night mare for a manufacturer
2015 FGX XR6 Turbo
Eaturbo is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 10:58 PM   #66
drew`SEVNT5
I think you should use a broader brush to make stupid generalizations next time.
Current
-2011 Nissan 370z Coupe (6M)-
-2006 Husqvarna SMRR450-
drew`SEVNT5 is offline   Reply With Quote Multi-Quote with this Post
