Old 18-10-2011, 09:00 PM   #1
XCwillo
Had Rep of GT-HO. Legit.
XCwillo's Avatar
Default Eeek! Lost a mates key to his Hi-lux, how do we replace it!?
So i borrowed his lux to do a quick run at lunch, and have misplaced it somewhere around my room... or the mess hall, or the 100 meters between my building and the mess :S
Its a 90's model lux, pretty old me thinks, just got a single little key, any ideas on what the go is for getting a new one? Do we have to go through toyota or can it be done by other parties??
Willo
I'm back! Finally.
XCwillo is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 09:08 PM   #2
XR Martin
XR Martin's Avatar
Default Re: Eeek! Lost a mates key to his Hi-lux, how do we replace it!?
Want to save a callout fee? pull the ignition barrell out and take it to a locksmith and they can cut a key from it. Otherwise call out one and they'll do all the work for you.
Also, the manual may have a 'key code' in it and if you take it to Toyota they can cut a key from it. They may be able to cut a key from the VIN too.
2004 BA wagon RTV project.
Old 18-10-2011, 09:20 PM   #3
b2tf
not here much anymore
b2tf's Avatar
check with Acc Cell and Duty Room? someone may have handed it in
2024 F150 XLT
Old 18-10-2011, 09:52 PM   #4
fmc351
let it burn
Or, if the door lock has the same key, just pull that and go to a locksmith.
fmc351 is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2011, 01:09 AM   #5
Kieron
Don't know about Toyotas, but i've seen key codes on either the passengers or drivers side lock barrel, i've also seen stickers with the key code on the inner door linings.
In both cases, you take the code to the respective dealer and they can cut a new key.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2011, 11:43 PM   #6
z80
Good locksmith will come to site and cut one on the spot.
costs money though i say about $200-$300
z80 is offline   Reply With Quote Multi-Quote with this Post
