Old 30-10-2011, 09:01 PM   #1
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Default Front hub bearing resistance.
Mods, please move if nessecary
In general, on a RWD car, how much resistance should there be in spinning the front hubs (with no brakes, discs, or wheels installed)? Should it free spin a bit or should it rotate easily but have minimal free spin?
Edit: hub installed and has abs and will easily free spin with brakes and wheels installed...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2011, 11:44 AM   #2
z80
Default Re: Front hub bearing resistance.
front, undriven wheel...yeah?
Once the initial mass is overcome it should spin with the force of one hand, easily.
if not, most likely the bearing preload is wrong or the wheel bearing is stuffed.
z80 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2011, 04:13 PM   #3
janddbone
B1 - J & D Services
janddbone's Avatar
As a general rule in this scenario there would be very LITTLE resistance indeed.
The easiest way to get it right in general is to tighten the nut up firmish, while spinning the wheel, to seat the bearing. Then back the nut off, and do it up finger tight with no tools, put the split pin in and done.
What model car is it, someone here is likely to know what exact torque you need and then you KNOW it is right.
Mr. Brett Johnstone.
2002 Ford Laser
2000 Ford Falcon Wagon Egas
1999 Subaru Imprezza Sportwagon
1998 Holden Suburban 2500
1995 Land Rover Discovery TDI
1994 XG XR6 Longreach
1983 Holden Rodeo
1975 Datsun 120Y wagon
1970 MG Midget
1967 Rover 2000TC
Soon: Model T.
janddbone is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2011, 05:30 PM   #4
XD 351 Ute
Excessive Fuel Ingestion
XD 351 Ute's Avatar
I back the nut off once the bearings have seated & use the weight of a 12" shifter falling to get the resistance just right.
Others may have differing opinions but that's what I was taught.
Failing all else, get a torque wrench and refer to manufacturers specifications.
Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay),
XD 351 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2011, 07:01 PM   #5
2011G6E
2011G6E's Avatar
It took me years to learn how to do this right...don't feel bad about being cautious about it seeing as how it's pretty important to get right...
Old 31-10-2011, 07:31 PM   #6
Jim Goose
The hub on my AU spins round and round more freely then a conventional set up on an older car with just plain bearings (pre AU), they dont really spin freely when torqued correctly.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2011, 07:40 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
The highlighted one. Will spin freely by hand but it wont keep going afterwards. Not enough mass there too. It will with the wheel on it.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
