Hi, Looking for somone with a capri to take a measurement on the leaf springs,
Need to know distance from center of spring pad to center of front leaf eye I was told that mk2 cortinas have same springs, need to check prior to ordering parts Thanks in advance
mk2 cortina, 2v clevo power, in build (still) This argument that you are carrying on with is akin to shuffling deckcahirs on the Titanic. |
I can probably try to get this for you over the weekend if no-one else does beforehand.
Tippy-tronic Free Zone
Mesurements (from FoMoCo v6 manual)
length between spring eye centres = 47in / 1194mm length from front spring eye to centre line of axle = 19.15in / 469.2mm width of leaves = 2in / 50.8 mm |
Thanks heaps guys
Got my caltracks today, same part number listered for mk1 cortina and capri so all good
TBA Customs
Mine are uneven length with the left(I think) about 5-10mm shorter, am I special??
Uneven length,,......hmmmm
Length between eyes straight line and following curve of spring (outside face) should be the same. If straight line different, then one has sagged or been 'decambered''...still special !! Also, I'm led to believe the V6and 4cyl springs were different ft/lb rates (v6 had bigger fuel tank and prob more rear squat on accel). Congrats, you are special !!! |
TBA Customs
LOL no I'm being quite serious, I know when I bought the car it pulled hard right when braking, harder even than me at 13
![]() At first I thought maybe mismatched pair, maybe an Escort one, but when I replaced them I swapped them over and sure enough it fixed the skewed diff as well as the pull under braking. So ye strange ![]()
Swapped springs as in L>R and R>L ? (not just replacement set?)
OR....was one just back to front, as in rear eye was at front on that side of axle (which would 'skew' the axle), but front bolt bigger diameter than rear....Hmmmmm...so maybe not. Man, that is weird. Skewed diff (now 'fixed') would certainly explain the odd braking, and crabbing down the road I bet. Suggests chassis is not square - trapezoid? aka wonky rectangle - .....measure diagonals FR-LR and FL-RR. Hope I'm wrong on this one. I do know the Renault 16 has uneven length rear trailing arms (!! True !!), but never heard that about Capri. (nice trivia question !!) |
TBA Customs
ye swapped L-R, trust me when I saw the skewed diff I feared the worst then when I saw the uneven springs I was scratching my head, so ye strange
