Old 15-11-2011, 08:07 PM   #1
raised by monkeys
raised by monkeys's Avatar
Default stock series I stereo into late model series II
g'day guys,
I have found a cheap early model fairlane stereo. Will it fit in my late model series II XR fascia?
If not, which ones are interchangable?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
Old 15-11-2011, 08:36 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: stock series I stereo into late model series II
The shape of the units doesnt change from series to series IIRC, some are single DIN as opposed to AUII onwards when they all went double DIN though.
I think you may strike compatibility issues if putting an S1 unit into anything else but someone may be able to confirm that.
Why are you bothering anyway? Decent headunit is under $200 now, youd be mad to even bother with the stock one.
2024 F150 XLT
Old 15-11-2011, 08:57 PM   #3
raised by monkeys
i just wanna use the face of it to cut up to make a surround for my double din dvd player, so it sits flush and fill in the gaps around it
cheers
Shaun
Current
Previous
Old 16-11-2011, 09:42 PM   #4
SSD-85
Au1 has different curve angle to au2. Side measurements are the same. Connector loom is wired different so wont function correctly.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2011, 09:46 AM   #5
raised by monkeys
as i said, i just wanna make a shroud for the double din unit i have in there, so it doesnt need to be connected, ill just be using the face of the stock stereo.
cheers
Shaun
Current
Previous
