Old 17-11-2011, 07:17 PM   #1
crazy.mofo
crazy.mofo's Avatar
Default replacing standard ba icc
Hi I am in the process of replacing the standard ICC in my ba xr8 ute with another because in the process of installing a aftermarket sound system we have fried the ICC.
What do i need to use from my existing unit to the replacement unit for everything to work properly ie air-con, remote locking, cd player? What is involved in decoding the new unit, and is it just the cd player that gets decoded or does everything have to get programmed to the car?
Cheers, Aaron
crazy.mofo is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2011, 08:17 AM   #2
FADI75
Sponsor
Default Re: replacing standard ba icc
Cheers, Aaron
hi
you will need to use the BEM and remote locking off ur old ICC, then get it recoded by ford where they can use their IDS
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
Old 19-11-2011, 04:51 AM   #3
sbcb
BA Xr8
sbcb's Avatar
If I wished to look at upgrading a basic screen setup in a BF XR6 and was only after the colour screen what is required for the swap? its single zone AC with single CD so do I need a colour screen ICC from a BA/BF with a similar setup single AC/ CD player and retain my old BEM + door locks OR do i need to replace the BEM also as the screen is changing? Thanks
My Ford List - AU1 Futura, AU1 Cobra XR8, EB Gli Project Car, AU2 XR8 200kw, AU1 Fairmont Ghia VCT, AU1 V8 Tickford Fairmont Ghia, BF Xr6 6spd ZF, BA MkII XR8, AU3 Fairmont, SX Territory, AU3 Xr8 220kw, BA Xr8.
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2011, 07:43 PM   #4
crazy.mofo
crazy.mofo's Avatar
Cheers, we sourced a replacement ICC and just had to swap the cd players. All is working except needs a decode but thats no biggy, I'm just glad my air con works again lol.
Also just out of curiousity, where is the sensor that apparently stuffs up the unit if it gets rotated the wrong way? We have assumed that it was the part hooked to the remote locking that hooks onto the side of the cd player and is wrapped in black tape, so we took extra care to make sure that we didn't turn rotate anything.
Old 19-11-2011, 09:32 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. There is no sensor. All the ford book says is not to put the icc down on it "class A finished face" asscratches are not covered by ford warranty and if the unit is a 6 stacker don't turn it upside down and shake it as the cd's can dislodge from the holders in the unit. Cheers MD
HI
I'M MICHAEL
Old 21-11-2011, 07:41 AM   #6
FADI75
Sponsor
hi
as long the icc u using for the upgrade have the same specs off ur old icc then all u need is to use your bem and central locking sensor off ur old icc and fit on the new one where after you will need a ford dealer to use their ids to bypass the code
cheers
fadi75
