Old 14-11-2011, 12:13 PM   #1
ben131185
Default rear guards rubbing SL 245/40/18
since putting short travel shocks in the rear to fix a bottoming out issue i have no noticed one of the rear tyres is scrubbing the guard on the rear.
It makes a pretty aweful sound when you hit a bump at 100ks and and rear end flexes.
I can see on the tyre where it has worn a bit where it makes contact, i can also see on the guard where it has touched.
I rolled the front guards a while back after they scrubbed but I never thought Id have an issue on the rear.
Anyone else experienced this?
Im thinking i might use a grinder to grind out the area thats fouling rather than rolling.
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2011, 12:16 PM   #2
ben131185
Default Re: rear guards rubbing SL 245/40/18
by the way im running federal 595 tyres in 245/40/18, never had any scrubbing with the same size tyres in silverstones, the federals are obviously slightly bigger
Old 14-11-2011, 10:20 PM   #3
FrogXA
Blown BF XR8
FrogXA's Avatar
I've got 275/35/19 Kumho's with Kings SSL on the back of my XR8 and had to grind a fair bit out where the metal guard meets the black plastic inner liner on the back of the wheel arch. I ended up parking the car diagonally on a steep driveway till I heard it touch, then I got out and marked where it hit with a felt pen. I used a thin cut-off wheel on a 4" grinder and cut a wedge out about 5mm wide on one edge and about 50mm long then neatened it up with a die grinder and painted the exposed metal. The die grinder worked well on the plastic inner guard as well.
You shouldn't have too much to grind away though as your tyres are a bit smaller than mine.
FrogXA is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2011, 09:38 PM   #4
ben131185
Hi Frog,
Sounds like the way to go, thanks.
Old 05-12-2011, 08:46 PM   #5
ben131185
Well... I got the grinder out and carefully cut out a section of each rear guard and using a brush primed the bare metal to prevent rusting.
No more scrubbing, a lot better over bumps on the fwy now ;)
Old 09-12-2011, 06:25 PM   #6
Day-mow
rexnet
Day-mow's Avatar
i ditched mine. if you get your guards rolled. thats the 1st thing they do
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 09-12-2011, 06:28 PM   #7
blueoval
Critical Thinker
blueoval's Avatar
Does this happen often with AU's with 245's on the rear?
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 09-12-2011, 09:10 PM   #8
adumb
FG G6ET
adumb's Avatar
I haven't had any issues with the rear, only the front. That with IRS however.
2009 FG G6E Turbo
adumb is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 09:34 PM   #9
ben131185
IRS might not be as bad because the top of the wheel will angle inwards as the suspension travels upward where as the live axle will stay straight if both sides are flexing equally as they generally will over a bump in the road.
