Old 02-01-2012, 01:31 AM   #1
bryan88
Default removing alarm system
So the Telstar TX5 is still parked. The distributor guys retested the distributor and said it was fine. They say that the Autowatch alarm/immobiliser systems give a lot of trouble when they get old. Does anyone know how to remove it? Thanks.
bryan88 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 07:09 PM   #2
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Default Re: removing alarm system
I just did a bit of a Google search on the Autowatch alarm and it appears to be fairly complex and will probably need to be removed by an auto electrician. I guess for obvious reasons if it was easy to remove it wouldn't be much of an alarm system
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 11:01 PM   #3
bryan88
Yeah, there's a guy locally that does them, guess I shouldn't be a cheap-skate. Thanks man, I'll keep you posted.
Old 04-01-2012, 07:17 AM   #4
Russ
Russ's Avatar
No worries, hope you get it sorted
