'06 Ford Territory Turbo
Hi All.
After a long weekend replacing the front end's wheel arm section thingo, we've realised that my AU's diff is also gone, and probably worse than the front end's problem. Long story short, anyone know if the EF's diff will go straight in to an AU, as I have one down the back of the yard in the old car? Cheers. |
#2 | |||
Back to Le Frenchy
If they're both live axle then the centres are a direct swap.
#3 | |||
#4 | ||||
Back to Le Frenchy
#5 | |||
#6 | |||
Back to Le Frenchy
Then you do have live axle (non IRS) so it is a straight swap of the centres.
not live axel, as i own a 99 model
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
ROCKING THE EL FUTURA
should be live axle mate.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
Don't mind my lacking terminology. So we swap the centers, but keep the arms that the axles run through and re-attach them?
#10 | |||
![]() Join Date: Jan 2005
From now on, you should refrain from posting your opinion and presenting it as fact. Either don't post, or preface your post with something like "I don't know this for sure, but I think, or my mate has told me.........." Teknoslasher - when swapping the centres over, you need to ensure that the gears mesh/lap properly and there's no play etc, so if you're unsure what you're doing, it might be time to take it to a diff specialist to get the work done.
#11 | |||
RG is talking about the internals when he refers to the "centres". You retain the AU axles but use the E series gears from the centre part of the diff. Good luck with the swap over.
#12 | |||
#13 | |||
And pulling apart is generally easy; it's the putting back together I sometimes struggle with.
#14 | |||
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
#15 | ||
don`t forget to check if the ratio`s are the same on the ef diff as on the original(same amount of teeth on the larger gear(crownwheel) and the small one that meshes with it(pinion).
#16 | ||
did the au falcon S have irs as well ?
#17 | ||||
Back to Le Frenchy
#18 | ||
The Monty
series 1 fairmont ghias were optional and you forgot T-series :P
#19 | |||
Walking with God
Glad I'm not the only one with the putting back togeter bit! GK
#20 | ||||
Back to Le Frenchy
#21 | |||
It sucks when you've done it so many times and it becomes not fun anymore, mabey i should stick to one car lol...........
#22 | |||
some people need to read gregory's more often and become familiar with their cars.
#23 | ||
also mate when doing things such as diff make sure you buy new bearings and shims its always good to know you have replaced things like that just for piece of mind.
#24 | ||
Well, at this point we have some good news. I've managed to pick up a diff from another forte, as well as the tail shaft. Best part is, its for free after some great business talking from my old man. They're apparently in really good nick, so fingers crossed all will be well.
#25 | ||
well done mate keep us posted.
#26 | ||
I would like to drop an LSD centre into bog standard au2 live axle futura sedan to help with towing etc.
On ebay I can get a reco 28spline lsd hemi and the seller informs me that all I will need to do is "use your crownwheel gear off your original hemi & bolt it on to the lsd hemi" So,is it that easy? Are there any pitfalls apart from changing the oil to LS90? Cheers |
