Old 15-11-2005, 02:23 PM   #1
FTE217
T3/Sprint8
FTE217's Avatar
Default Rear Window Stop Light
I'm sorry being lazy here, now that I have gone to a Boot Lid look at the rear I think I better get my brake light working inside the rear window before I get tailed by a Patrolman and get booked for something so stoooopid : :
They are obviously not connected having the usual spoiler fitted with the brake light in the wing, has someone done this before ?
Is the bulb just missing or fuse or what ?????
What bulb do I need to buy,or maybe it's in there,should have a closer look I suppose.
How do I get to this tight little situation ?
Thanks in advance :
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 15-11-2005, 02:50 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
On my XR i have the stop light on the spoiler and also the one inside the window dunno why u dont have u ever had the window light working? It could be just a broken globe
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 02:56 PM   #3
DOC
DOC's Avatar
I may be wong, but if you have a spoiler the rear window light is not connected ( by means of just leaving the globe out ) as the law states you should only have one rear ( central ) brake light.
without the spoiler all you need to do is intall the correct globe into the existing rear light and from memory look up inside of your boot for access.
Pete
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 03:06 PM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
its a large wedge bulb iirc
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 03:06 PM   #5
JC
JC's Avatar
Blue Driver, Not only is the bulb not there, but the red glass/perspex/diffuser is also not there. If you look carefully, you will notice that it is a piece of black plastic taking up that space (at least in series 1 XRs). So, you will need to get a rear brakelight from Ford, or the wreckers. I got mine for $15 from the wreckers when I was driving around spoilerless for a while. You will also need a bulb.
To change the black plastic to the proper brake light, you need to remove the rear parcel shelf cover. It's pretty easy - just get some new Xmas tree lips as the old ones will be buggered.
Ford Performance Club ACT
Old 15-11-2005, 03:18 PM   #6
b2tf
not here much anymore
b2tf's Avatar
Maurie it should be a simple matter of putting the bulb in.
2024 F150 XLT
Old 15-11-2005, 03:33 PM   #7
FTE217
T3/Sprint8
FTE217's Avatar
Thanks very much fellas, cheeez something simple as usual seems a pain in the backside especially after JC's reply lol it sounds like they made it easier for the S3......thanks Aust after speaking with Darkhorse it seems as easy as just putting a wedge bulb in the it's place.
You are right DOC, here in NSW I know if you had the spoiler light all never had the window bulb connected.
Thanks again for your help bulb shall be purchased on the way home.
Daily Macan GTS
Old 15-11-2005, 03:33 PM   #8
richo77
richo77's Avatar
Agreed and tried and tested by me. Its just the push in style globe that goes in. Everything else needed is there ready to go ie wires/globe holder etc etc
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 03:34 PM   #9
richo77
richo77's Avatar
Originally Posted by Bluedriver
Thanks very much fellas, cheeez something simple as usual seems a pain in the backside especially after JC's reply lol it sounds like they made it easier for the S3......thanks Aust after speaking with Darkhorse just know it seems as easy as just putting a wedge bulb in the it's place.
Beat me to it :
Old 15-11-2005, 04:30 PM   #10
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Righteo so if you took the brake light lens out, you can access the internals of the stop light? Reason I ask is that in getting the clip undone for the bulb connector to explain to BD, I stuffed up putting it all back in ie the bulb is now somewhere inside the stop mount and buggered if I can get my fingers in and around there to get it back out again!
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 04:59 PM   #11
FTE217
T3/Sprint8
FTE217's Avatar
beauty Darkhorse help me out and stuff yourself up :
Again thanks.
Daily Macan GTS
Old 15-11-2005, 05:10 PM   #12
FalKeen
FTF Car Club NSW
FalKeen's Avatar
lucky its a simple fix, could see maurie coming down to work again for a little help
FalKeen is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 06:16 PM   #13
JC
JC's Avatar
It would make it easier, yes.
Old 15-11-2005, 08:15 PM   #14
FTE217
T3/Sprint8
FTE217's Avatar
: I was thinking about it :
Daily Macan GTS
Old 21-11-2005, 07:58 AM   #15
Casper
Contributing Member
Casper's Avatar
Just looked at mine and its just like JC's. Just a plastic cover, no lens at all.
Looks like I'm keeping some sort of wing cause I couldnt be stuffed getting it all sorted.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
