Old 27-04-2012, 02:24 PM   #1
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
Default AU V8 Diagnostic Unit?
Just wondering what interface units people are using to pull codes from their AU's.. i have a spark issue i want to narrow down on the au2 and i'm hoping one of these might help.
Also please specify if it's just a code reader, or an interface which requires a laptop plugged in and appropriate software
cheers all
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2012, 02:34 PM   #2
Default Re: AU V8 Diagnostic Unit?
saw this one listed in another thread, has anyone confirmed it works with the AU like it claims??
http://www.ebay.com.au/itm/MaxiDiag-...item2c54863fd5
Old 27-04-2012, 04:33 PM   #3
Ride
Stay Classy ™
Ride's Avatar
I have an OBD II reader which supports all the ODB II protocols and it didn't work for me, the AU has a wierd protocol which any of the eBay readers won't be able to pick up. The only way people are getting ECU data is through quarterhorse boxes.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2012, 05:00 PM   #4
ah ok that's a bugger as i don't plan to go down that route
thanks mate
Old 28-04-2012, 10:25 AM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Prof, take it to Ford and ask them to see if there are any codes on it? Surely it would not cost a lot for a code read, but then again I may stand corrected. Ford uses a NGS, which they did on mine (pre Quarterhorse) when I had a fuel pump problem and told me I may have a problem with my coils! Point being, even if you do see a code, it may not necessarliy point to the problem.
On the OBDII thing, AUs run a bastardised version of OBDII, so as Ride found, a normal OBDII reader may not work.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2012, 10:26 AM   #6
yeh i'd do that but from my new ford days, i'd just expect them to say it spat no codes at all when the car was basically falling apart
