Old 12-04-2012, 07:04 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default Whose changed rear sway bars in IRS
What's the trick. Went to have a crack at it after night and it's a million times harder then the front.
Appreciate any help. Thanks
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 13-04-2012, 08:23 AM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Default Re: Whose changed rear sway bars in IRS
Damo, check in the tech resources how to. I wrote up a how to on this.
http://www.fordforums.com.au/vbporta...rticle&id=1302
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2012, 01:41 PM   #3
Day-mow
rexnet
Day-mow's Avatar
Champion.
Old 13-04-2012, 01:41 PM   #4
Day-mow
rexnet
Day-mow's Avatar
Champion.
Old 13-04-2012, 02:15 PM   #5
Day-mow
rexnet
Day-mow's Avatar
Wow. Hit enter a fee to many times. So you have to take out the drive shafts? That's gay
Old 13-04-2012, 04:50 PM   #6
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
I have heard of it done without taking the half shafts out, but given the room that you have under there, it is much easier with one or both half shafts out. Not sure about the sexuality of your rear suspension though?????
2002 AU II LTD
Old 13-04-2012, 06:17 PM   #7
Day-mow
rexnet
Day-mow's Avatar
This is going to be lame then.
If I need to take out drive shafts it's deff gay
Old 13-04-2012, 06:27 PM   #8
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
I am sure that you have tackled harder jobs mate. It is just a bit more time consuming than those with live rear axles are used to.
Have you got a new one to go in? I am sure that it will be worth it if you have.
Stu
2002 AU II LTD
Old 13-04-2012, 08:53 PM   #9
Day-mow
rexnet
Day-mow's Avatar
Yeah got a pedders one posted for $150 pretty happy with it. Mich give it a crack tomorrow after work.
Old 13-04-2012, 08:57 PM   #10
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Good work. Great price. What size diameter?
2002 AU II LTD
Old 13-04-2012, 10:50 PM   #11
Day-mow
rexnet
Day-mow's Avatar
everything im reading says 20mm 3 point adjustable. im pretty confident its not adjustable. but its probably about 20mm.
its at work i was gonna fit it last nite there but no cigar. so i'll bring it home 2morro and sus it all out!
Old 01-05-2012, 10:02 PM   #12
Day-mow
rexnet
Day-mow's Avatar
Well I've tried again and no success probably will end up dropping the diff. Took out both drive shafts and still couldn't swap them. It's starting to really tick me off.
Old 02-05-2012, 08:52 AM   #13
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
MMM, both drive shafts out? I certainly got mine changed with both shafts out! Took a bit of jiggling, but not too much.
2002 AU II LTD
Old 02-05-2012, 08:06 PM   #14
Day-mow
rexnet
Day-mow's Avatar
Definitely can not do that in mine. I tried for a hour and had 0 luck
Old 02-05-2012, 08:13 PM   #15
FreddyDUZ747
FreddyDUZ747's Avatar
Yep thats gay as aids Daymow...
I guess this is only thing the BA rear end has over the AU,mine took about one Iced Coffee to fit lol.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2012, 08:56 PM   #16
Day-mow
rexnet
Day-mow's Avatar
to right Karl!!!! i want it to be as easy as the front! im gonna try lowering the diff but leaving most things attached and hop that it'l all hold in place and i'll be able to get it out/in.
Old 02-05-2012, 09:11 PM   #17
raised by monkeys
raised by monkeys's Avatar
Hit me with a text if you need a hand. Heading out of town midday saturday though.
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
Old 03-05-2012, 09:08 AM   #18
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Day-mow, did yoy try to loosen the front (verticle) diff bolt? It allows you to pull the front of the diff down. It may give you the clearance you need.
Stu
2002 AU II LTD
Old 04-05-2012, 05:47 PM   #19
Day-mow
rexnet
Day-mow's Avatar
Thanks man. I'll just do it at work oneday
Old 04-05-2012, 05:47 PM   #20
Day-mow
rexnet
Day-mow's Avatar
Stu
Sure did. Still no luck :/
Old 04-05-2012, 09:47 PM   #21
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Hang in there - I'm sure we've all had days like this.
Would getting a prybar and levering the control arms help? May give you some more room to manouvre the bar out?
Just a thought.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2012, 12:52 AM   #22
Day-mow
rexnet
Day-mow's Avatar
Just a thought.
Effectivly had a go at that. Pretty certain Diffs gotta be dropped
