Go Back   Australian Ford Forums > Ford Australia Vehicles > Small and Mid Sized Cars > Cougar and Probe
Old 04-06-2012, 10:44 PM   #1
paul macey
Default Ford Probe V6
Engine will turn over but will not start.Fuel Cut Out Light staying on.Have tried resetting Fuel Shut off switch (in rear compartment) but still will not start).Reset on switch does not appear to do move up or down when touched/pushed down?Is this normal?No noise evident from Fuel Pump.Thanks
paul macey is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 11:45 PM   #2
IceValk85
MY2010 SV6 SIDI -Black-
Default Re: Ford Probe V6
dead fuel pump?
IceValk85 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2012, 11:50 AM   #3
Lightning Strike GT
Lightning Strike GT's Avatar
I know this an AFF forum - but look here http://www.probetalk.com/
We have a Probe and it has done this but it was a just a reset of the cut out switch - a big pot hole jarred the car and cut it out
Regards Alan
FG GT in Lightning Strike
5th anniversary edition in manual 1 of 25
And an 2019 MD Mondeo Trend Wagon in Platinum White
Lightning Strike GT is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2012, 05:06 PM   #4
paul macey
I have checked Fuel Pump & Fuel Cut Out Switch today & neither have power going to them?Thanks.
Old 06-06-2012, 03:04 PM   #5
Mr H
I had mazda 626 V6 2.5 Which is virtually the same engine. When does it cut out, after its warm, after you have been for a drive or it just doesn't start regardless? I would be checking the distributor as these are notorious for cutting the engine out when warm or for no apparent reason. I found that when i sprayed freeze spray on the dizzy itself, the car would start again.
Mr H is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2012, 08:19 PM   #6
BPXR6T
^my neighbour had the same problem with her probe. Not related to being warm though. Sometimes she'd go out and it would start first go then other times nothing. Was a dodgy dissy. Replaced it and never a problem since.
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2012, 10:29 PM   #7
Mr H
the thing that sucks is that a dizzy will set you back $400-500. and yeah it did fix the problem
Old 06-06-2012, 10:43 PM   #8
divine_afg
Extreme_Custom
divine_afg's Avatar
its the spark plug distributor. common problem. repco stocks new ones for about 500.
If You Think AU Are Ugly ! Check my X Out.........
Loved by one ... Admired by many ... Envied by most !
RIP - F6
divine_afg is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2012, 11:08 AM   #9
Lightning Strike GT
Paul - Give one of my old sparing partner Andrew from the old Probe Talk days / auscar talk days a PM - he is a whizz on all things probe
http://www.fordforums.com.au/member.php?u=331
Regards Alan
Old 07-06-2012, 05:58 PM   #10
snowcone
Or get on the Mazda forums, after all, it's an MX6 engine
snowcone is offline   Reply With Quote Multi-Quote with this Post
