Old 26-07-2012, 06:21 PM   #1
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Default Genuine Big Block
A friend sent me these Photos:
Would have been a real monster. Torquey One Tonner though.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is online now   Reply With Quote Multi-Quote with this Post
Old 26-07-2012, 06:45 PM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: Genuine Big Block
It was actually two 6 cylinders made into one, hence the twin 6 name. 4 cylinder heads.
Needs to learn how to spell distributor.
Old 26-07-2012, 06:51 PM   #3
cedric
'elvis' of rodbods by elvis built a 32 three window(i think) with one of these in it have a look on his web site if you want a look
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2012, 07:16 PM   #4
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
this one?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2012, 07:24 PM   #5
Nikked
Oo\===/oO
Nikked's Avatar
Shared a common block....
351 V6
\≡≡T≡≡/
Old 26-07-2012, 07:35 PM   #6
Bossxr8
Peter Car
Bossxr8's Avatar
Yeah, they made the block casting and crankshaft as one piece rather than two. But still bolted 2 pairs of heads each side.
Old 26-07-2012, 09:19 PM   #7
Burnout
Burnout's Avatar
Found some info:
GMC produced a large gasoline-burning V12 from 1960 to 1965 for trucks, the "Twin-Six"; it was basically GMC's large-capacity truck 351 V6, doubled, with four rocker covers and four exhaust manifolds.[6] Fifty-six major parts are interchangeable between the Twin-Six and all other GMC V6 engines to provide greater parts availability and standardization. Its engine displacement was 702 cu in (11.50 L), and while power was not too impressive at 250 hp (190 kW), torque was 585 lb·ft (793 N·m). For firetrucks the rev limiter was increased to produce 299 hp (223 kW) at 3000 rpm and torque was increased to 630 lb·ft (850 N·m) at 1600-1900 rpm. It was possibly the last gasoline engine used in heavy trucks in the U.S.
Quoted from: http://en.wikipedia.org/wiki/V12_engine
RTV Power
Old 28-07-2012, 09:14 PM   #8
CAMS290
trying to get a leg over
CAMS290's Avatar
They were put in GMC "Cracker Box" trucks
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2012, 09:51 PM   #9
SSD-85
Meh, the 385 series is the REAL big block. One motor, 8 cylinders of of GM-crushing power.
(Hey, this is a FORD forum, nothing wrong with favouritism)
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 03:58 PM   #10
Angeldust
Angeldust's Avatar
haha someone should weld two 3.8ltr ecotecs together in their vn
Z series Clubsport HRT edition..
e46 320ci 2.2ltr Stocko
Angeldust is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 04:03 PM   #11
MWTB
I'm old and I fell
MWTB's Avatar
I believe it was a Buick in the VN.
BF2 XR6 turbo
82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far.
Ozracing coilovers, Pedders sway bars front and rear.
315rwkw
MWTB is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 04:12 PM   #12
ZH302c
You are correct, Ecotech didnt come out untill vs.
ZH302c is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 04:17 PM   #13
TUF_302
The Vengeful One
TUF_302's Avatar
Be careful you will give Riksta ideas! lol!
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
