Old 17-08-2012, 02:14 PM   #1
79da
79da's Avatar
Wink Help with BTR 4 spd auto required.
G’day.
Does anybody no a 4spd auto guru in Melbourne? Mine is playing up. Its been to a couple of workshops. The first business won’t be getting my business again.
Problem of no torque converter lock up could initially be fixed by swerving hard to the right. A couple of bumps helped. Now it will only engage if a can find a hill that is long and bumpy enough to decend at 110klm. Oil level is as it should be.
Riding without lock up adds a lot of heat to my coolant temp I have also noticed.
It used to run 1st -2nd-3rd-3rd over-4th-4th over. Starting at 60klm.
Now it just runs 1st-2nd-3rd-4th with no converter lock up. Flat out.
Ford dealers diagnosis was helpful whereby they came up with the following:Performed test on trans solenoid pins. Found to be all ok. Connected to IDS and tested, road tested and found vehicle to hold onto forth gear and not enter lock up. Using a data logger found all solenoids to be selecting OK except converter lock up.
Their feeling was that the engine is not communicating with the gearbox well. To start with a trans C/o and take it from there. Was told that the TPS could effect the running of the tranny but to start with a repaired transmission first.
Does this sound correct??
I am confident I can replace the converter and s7 solenoid but not sure that doing so will rectify my problems.
The box feels smooth. Nothing a ‘band adjustment’ and new oil wouldn’t fix if I can repair the lock up.
My feeling is it could be any number of electrical faults causing the problem such as TPS, pedal box, faulty wiring or earth.
I really need to take it to somebody who understands these gearboxes.
I’d like to build a built proof BTR such as described by some of the members here but not sure which direction to take as I am planning on swapping the green motor for a petrol so I can add vapour injection. A 6spd is on the wish list until I’m told its impossible or impracticle but thats a whole other can of worms.
Appreciate any feed back.
Cheers.
79da is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2012, 04:04 PM   #2
V8 Ghia Mike
Blue blooded Ford guy!
V8 Ghia Mike's Avatar
Default Re: Help with BTR 4 spd auto required.
Try pulling apart the wiring harness plugs up in the engine bay and giving the pins and sockets a good clean out with electrical contact cleaner for starters.
Mike
09 FG G6E Turbo
Ego grey, Cashmere leather, factory 19" wheels, Monroe GT/King SSLs, stock Barra, still goes hard...
94 EF Fairmont Ghia 5.0- XR8 in a tuxedo...
Bordeaux purple, Tickford kit, 2.5+ inch drop, EL Ghia chrome, leather, Pioneer sound, C&C, electric everything, 18" BA XR8's, ABS, LSD, GT40P's, Crane cam, ChipTorque ECU, XR8 snorkel, lots of woodgrain, chrome and interior lights.
V8 Ghia Mike is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2012, 06:36 PM   #3
79da
79da's Avatar
Thanks Mike. I'll give it a go tomorrow. Should I do them all such as knock / oxygen, temp, tps, etc. Do you mean also pcm plug? If so, is their any draw back for disconecting pcm??
Will do trans connection also. RE: transmission wiring seems poorly supported. Just noticed power cable from battery to pcm is the same.
P.S. I had the wiring all disconnected when I did the H gasket repair a couple of months back. After reasembly the auto ran great for half a day. Just thought it a fluke at the time. Only one way to find out. This time I'll clean all the plugs as you mentioned.
Ta
Old 17-08-2012, 08:09 PM   #4
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
If the car is running too cold, faulty ECU/PCM coolant temp sensor and/or not entering closed loop operation, generally, the trans will not lock up.
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
