Old 20-08-2012, 07:10 PM   #1
BAXTWAGS
BAXTWAGS's Avatar
Default What headlight restorer do you use?
What headlight restorer do you use ( to fix hazy cloudy and yellowy headlights ), why do you use it, where did you get it and how much
AU S1 Falcon .
BAXTWAGS is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 07:12 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Default Re: What headlight restorer do you use?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 07:21 PM   #3
Kryton
Kryton's Avatar
just get any polish and an electric buffer - itll take you longer to set up than do the headlights.
Old 20-08-2012, 07:24 PM   #4
mash85
my EFwent cloudy and crap. i used Plexus plastic polish. Came up pretty good. for headlights a bit more gone, you can uase the plexus in conjunction with a light sanding.
mash85 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 07:30 PM   #5
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
http://www.fordforums.com.au/showthread.php?t=11366745
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 07:30 PM   #6
Nikked
Oo\===/oO
Nikked's Avatar
That kit i use has a UV coating that prevents them from turing yellow again.
\≡≡T≡≡/
Old 20-08-2012, 07:33 PM   #7
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
brake fluid also works but be bloody careful
yift is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 07:43 PM   #8
BAXTWAGS
BAXTWAGS's Avatar
Okay cheeers guys
thanks for the link supershifty too !
Supercheap would be the best bet to get them from?
Old 20-08-2012, 07:52 PM   #9
supershifty
Missing a sock...
Yift, I'm interested in what you say about brake fluid - how does it work, and how do you apply it? or is what you're saying just a gig?
Cheers mate!
Old 20-08-2012, 07:59 PM   #10
pcman
2000grit on a dual action orbital sander, takes about 2 mins per headlight
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 08:11 PM   #11
supershifty
Missing a sock...
http://www.fordforums.com.au/showthr...t=el+headlight
This also. but I think this is related to extreme cases.
Full cheers to the member for posting this one up!
Edit: Yes, I've been thread mining!
Old 20-08-2012, 08:45 PM   #12
dallasv8
5.8 litres of fun
dallasv8's Avatar
i just used cut and polish on my EF Fairmont,worked just as good as the proper crap and with a lot less hassle
2003 RTV
2015 Ranger XLS mk2
dallasv8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 09:43 PM   #13
yift
Cheers mate!
No joke.
a friend of mine had an integra with the 4 healight front and we put brake fluid on a rag and gave it a wipe. his front bar was faded to all buggery so we didnt care about the paint, and the lights looked brand new for the next few years. i also did it on a few transits and skylines and some ef falcons.
Old 21-08-2012, 10:04 PM   #14
guidedog
yes works well ,have done 4 cars . use wet and dry sand paper fine ,then i use scratch x car cutting compound after that i use a polish . before and after are amazing. lights are brighter ,no more dull lights
guidedog is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 10:11 PM   #15
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by Nikked
Thoroughly recommend this one.
2024 F150 XLT
Old 21-08-2012, 10:23 PM   #16
TheInterceptor
Cruising...
TheInterceptor's Avatar
I used ScratchX which works, but the lights appear to slowly go yuck again after a month or so, least it did with my old truck!
FBT '98
F100 4x4 '82
S Pac '89
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 10:40 PM   #17
guidedog
i use a good car polish with a uv filter after i use scratch x ,seams to last ok on my cars
Old 21-08-2012, 11:31 PM   #18
TheInterceptor
Cruising...
Ah yes, thanks. I just bought new headlights haha, though ill be sure to remember your way when these do eventually go.
FBT '98
F100 4x4 '82
S Pac '89
