20-12-2005, 12:18 PM | #1 | ||
firstly guys i need your opinion on how low i should drop the car? im thinking 3" but am still undecided.
Second, i am have a problem with the car when i put the air con on.....every time i have it on a ticking noise comes from behind the glove box.....any suggestions on what it may be? thanks in advance |
20-12-2005, 02:50 PM | #2 | ||
anyone? help
20-12-2005, 03:06 PM | #3 | ||
slow & low EA Ghia
no idea about the aircon. but if u want to lower your car, grab a tape measure, measure from the ground underneath the tyre to the guard, then measure from the ground again to were you want either the front or rears to sit, figure out the difference and go to a spring shop and ask for a set of springs that are 6.9cm lower then standard. but be ware, that your springs (if its an ea) are 17 or so years old and that they might ahve sagged over the years. also if your car is an ea s-pack or xr it has lower springs, something about 30mm. if you dont really care how low it is then go and ask for some ultra lows for the rears and super lows for the front. looks good.
hope this helps Ehab
Ea Fairmont Ghia 1988 |
20-12-2005, 03:09 PM | #4 | ||
Aircon noise would be leaves or something in the heater/aircon fan.
