Old 09-01-2013, 11:58 PM   #1
Daniel B
Daniel B's Avatar
Default Ideas for transporting Engine
Hi guys, need to transport a windsor. Looking for ideas.
My plan at the moment is to put it on a trailer with some timber blocks under the engine mounts to take the weight, and extra blocks under the back of the sump and some under the crank pulley to stop it tilting forward or back.
What are your thoughts?
Daniel B is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 07:05 AM   #2
cowboy
Cowboy
cowboy's Avatar
Default Re: Ideas for transporting Engine
Get an old tyre (no rim) and stick the sump in the middle of it, tie it down to stop it rolling over and you're done. I've transported many many motors this way with no damage.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1930 Pontiac Landaulet
1932 Pontiac V8 sedan
1935 Pontiac sedan
1937 Pontiac 8 sedan
1948 Pontiac silver streak
1949 Ford F3 pickup
1953 Pontiac Chieftain
1955 Austin Champ
1957 Dodge Power Wagon
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
cowboy is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 10:26 PM   #3
Daniel B
Daniel B's Avatar
yeah thanks for that mate, I have done that previously also but with a 2cyl, and it still ended up sitting on the sump which i'd like to avoid, and this thing would weigh double.
Old 11-01-2013, 09:08 PM   #4
redxm
64 Deluxe 4 door
redxm's Avatar
yep. old tyre and a couple of ratchet straps. if you are worried the sump might hit the trailer find a 4wd tyre
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2013, 09:26 PM   #5
cowboy
Cowboy
cowboy's Avatar
Yep, I use a 4x4 tyre and never touch the sump.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
Old 11-01-2013, 10:31 PM   #6
Daniel B
Daniel B's Avatar
Thanks for the ideas guys, wouldn't have thought the tyre would stand up to the weight of the engine and would just flatten out. Very good to know.
Old 11-01-2013, 11:55 PM   #7
cowboy
Cowboy
cowboy's Avatar
It compresses to a point but ends up sitting on the crank pulley and the rear of the pan on the sidewalls. 4x4 tyres won't flatten out nearly as much as car tyres.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
Old 12-01-2013, 12:08 AM   #8
rst2000
or just double stack a 4wd tyre....prob solved.
rst2000 is offline   Reply With Quote Multi-Quote with this Post
