Old 15-12-2005, 07:38 PM   #1
DentEd XR8
DentEd XR8's Avatar
Default Accuracy of Odometer Diagnostic Mode
Hey guys, just wondering what everyone thinks of the accuracy of the diagnostic mode of the odometer on EF/EL instrument clusters, reason I'm asking is cos there is a 3km difference between the digital speedo and the analogue speedo. And also the fuel consumption figures seem to be way over the top.
I'm tossin up on gettin a trip computer but if it's accurate there would be no point
Ed
DentEd XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 08:14 PM   #2
woodstock_rocks
the cluster gets the same information from the ecu as the trip computer would. So it's much of a muchness..
Old 15-12-2005, 08:48 PM   #3
Age182
GMHKLA number plates
Age182's Avatar
mines 5kms differance :S
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 08:55 PM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Well I just got into a little debate with other's about the accuracy of gauges in vehicle's on the Territory page, but put it this mate, they are a guide, now speed gauges have allway's been inconsistant, because manufacturer's only need to be within 10% and fuel gauges are somewhat familiar.
Old 15-12-2005, 09:15 PM   #5
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
The analogue speedo is set to read a couple of km/h less than what you are really doing, which explains the difference from the diagnostic mode speedo, which is what the car thinks it is doing - and may not be accurate in itself... I can't remember exactly how the fuel consumption works as it has been a while since I used diagnostic mode but there are a couple of different readouts and they are not all in L/100km
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 10:38 PM   #6
Madhatter
EF Fairmont Ghia
dont forget there are different modes, unbuffered and buffered. They effect the readings as buffered essentially evens out the scale to stop it swinging wildly.
Madhatter is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 10:42 PM   #7
335JET
@jas_23_
335JET's Avatar
mine is about 3 km/h diference, but i thought that was because i changed rim size.
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 10:45 PM   #8
335JET
@jas_23_
335JET's Avatar
speaking of the diagnostics readouts on the el/ef dash cluster, does your digital oil preasure guage on the odometer readout work because mine always says zero.
Old 21-12-2005, 11:21 PM   #9
Kaddis
Kaddis Customs
Kaddis's Avatar
how do you get into that mode?
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2005, 12:56 AM   #10
darnoldrs
http://www.fordmods.com/phpBB2/documents.php?doc=12
this all the info here.
RIP, EL series 1 XR8, Manual, 3.45 LSD, 347 Stroker, Big bore Pacemakers, and K&N. 180.2 rwKw
Replacment,
FG MK1 FPV GT-P, Manual, 5.4, Stock Standard everything.
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2005, 01:20 AM   #11
Madhatter
EF Fairmont Ghia
yes mine works.
Old 22-12-2005, 12:24 PM   #12
arm79
arm79's Avatar
The needle is set to show the speed as 3 to 4% higher than the actual vehicle speed. This is done by the factory to:
1. Allow for tyre diametre differencee- Inflation, tread depth, size differences
2. Allow for the overspeed with cruise control when it comes to the crest on a hill, before it starts disengaging. Saves you from getting a speeding fine.
Both of these were reasons discussed on a plant tour.
The only way round it is to get a cop cluster. Mine is set so the needle is showing 100 when the car is doing 100... You then notice how you are always going quicker than every car on the freeway.
arm79 is offline   Reply With Quote Multi-Quote with this Post
