Old 23-02-2013, 12:14 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Thumbs up Ford Taxi clocked at 400+ kph
Finally after years of frustration with rain delays and niggling problems.. Norm Bradshaw has broken the 400kph barrier with a Stella run at 408.7kph on the first day of Speed Week held at sunny lake Gairdner in Sth Australia .
The Dynomotive prepared 441ci small block Ford powered its way through the 3 mile traps on low boost at 6500 rpm
On day 3 when Norm lined to move the World record ( which is only 11 mph away) Norm decided to run the higher boost setting ( still relative low at 16 psi) but the twin plate Crower clutch let go and the taxi could only manage 400kph. The team has now set its sights on a return to Boneville to wrestle the World record back.
Well done all involved
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 12:28 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Default Re: Ford Taxi clocked at 400+ kph
Did it go through the maccas drive thru though, that's the question?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 12:38 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Wonder if that roof mounted thing is removed when racing? Would cause a heap of drag at those speeds wouldn't it? They did choose the right car for the job ;)
___________________________
Old 23-02-2013, 02:11 PM   #4
redxm
64 Deluxe 4 door
redxm's Avatar
would hate to see the fare on that run.
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:20 PM   #5
new2ford
new2ford's Avatar
Get me to the airport fast driver!
Oh hang on, forget the plane, just drive me to Melbourne.
new2ford is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:26 PM   #6
Mechan1k
Mechan1k's Avatar
See ... not all AU's were bad ... they at least had an excellent Drag Co-efficient rating.
Old 23-02-2013, 05:05 PM   #7
monte.b
monte.b's Avatar
so did they hold the world record at some time
monte.b is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 05:23 PM   #8
Phil B
Clevo power!
Phil B's Avatar
What record are they going for?
I've been keeping an eye on the Slaughter Motorsports streamliner and they did really well too, got over 400km/h as well. Would have been cool to be there!
The beast: XB coupe, 302, manual all the way!
Fixing up thread
The purple monster, daily BA XR6 turbo.
Scale Lego Technic XB Coupe with working bits! Build thread
Phil B is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 06:33 PM   #9
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Now that is an engine.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 06:51 PM   #10
Neale
Neale's Avatar
does it have a beaded seat cover
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 07:23 PM   #11
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
... that was done with just over 600 000Km on the clock too!
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 07:42 PM   #12
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Being a Taxi it must run on LPG. I wonder if its has an airod mixer
UK
Old 23-02-2013, 09:35 PM   #13
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
That is Falcon awesome!!!
Well done, that is some crazy speed. I've often thought the AU would be the perfect vehicle to go for records in being so slippery.
Good luck and go get that world record (back)!
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 09:45 PM   #14
Night
Wonder if he new where he was going?
Night is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 09:51 PM   #15
Bucknaked
Bucknaked's Avatar
I was thinking this was going to be a story on a faulty speed camera. 400 kph is awesome
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 23-02-2013, 11:15 PM   #16
xr gr8
Winter White Weapon
xr gr8's Avatar
Anyone who's been to 200kmh know its fairly moving...240-250 is scary stuff IMO but 400+...in a AU ( no disrespect here, I love em!) even highly modified is dead set proof someone has some big goolies
FG FVI
XFT Enhanced
360rwk/806nm
xr gr8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 11:36 PM   #17
79FordEsky
79FordEsky's Avatar
Well done to the guys who built this, would love to use it against top fuel cars.
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2013, 01:55 AM   #18
Phil B
Clevo power!
Phil B's Avatar
The problem with that is that this thing would take way longer than 1/4 mile to get to that speed. I think I heard that the track out there was 8 miles, so acceleration off the mark wont be that great. Though in a race to 8 miles this would win, with the top fueller not lasting the distance. A real credit to those who build these engines, crazy power but have to last far longer at full throttle than a drag car.
Fixing up thread
Old 24-02-2013, 05:55 PM   #19
BA-XT
2003 BA Falcon XT
BA-XT's Avatar
Reading in Motor Magazine today about the writers / editors scaries moments in a car. It was said that the BA's weren't speed tested above 220km. The guy got up to 307km in a modified XR6 Turbo and lost control, causing the brakes to go on fire... Said the rear wing did nothing and the back end let go. Was conducted on a runway.
Wonder what 400km plus in an old AU feels like!!
2003 BA Ford Falcon XT
IMPCO LPG Vapour Injection.
DETAILING
Meguiar's NXT Car Wash
Collonite #845 Insulator Wax
Bowden's Own Happy Ending & Fully Slick
Chemtech CT-18 Truck Wash (Wheels & Chassis)
Bowden's Own Wheely Clean & Tyre Sheen
Bowden's Own Three Way Paint Decontamination Spray
OILS AND FILTERS
Nulon Full Synthetic 10w-40
Nulon Long Life Coolant
Ryco Oil & Air Filters
My Instagram Account: @ba_falcon2003
BA-XT is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2013, 08:13 PM   #20
redxm
64 Deluxe 4 door
redxm's Avatar
No different than a run from the airport to blacktown in a cab............
XM Deluxe
FG XR50
BA Pursuit Ute
Old 24-02-2013, 08:30 PM   #21
rex351
Bugger! I was at Gairdner that day, left for home about 3 pm 'cause another car had taken out the long course timing equipment and was going to be ages to fix. Heard on the radio that the taxi was in the next group to run after the timing was fixed. Missed it by minutes by the sound of things. Well done Norm!
rex351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2013, 08:49 PM   #22
Nikked
Oo\===/oO
Nikked's Avatar
Most are geared so low they need a push start...
\≡≡T≡≡/
Old 25-02-2013, 09:59 AM   #23
EDManual
EDManual's Avatar
any videos? Would love to see it blasting past at 400kmh!!
EDManual is offline   Reply With Quote Multi-Quote with this Post
