Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 10-03-2013, 02:27 PM   #1
XR8_ash
2 wheel pilot, V8 novice.
XR8_ash's Avatar
Default Rear shock question.
Guys,
As my BA XR8 ute has just turned 100,000kms old I want to replace bits and pieces. Now I am going to get some new rear shocks put in. I have lowered the ute in the rear by 1 inch via blocks and just want to know if I should buy STD height shocks OR "low travel" shocks ?????
BA XR8 UTEHurricane 4-1 tuned extractors|3 inch cats|X-Force twin 2.5 inch cat back|Growler CAI|Whiteline sway bars F&R|Slotted rotors|KPM tune
YAMAHA R1|-1+2 gearing|Jet kit|Arrow exhaust
GSXR AUS SUPER SPORT race bike|K1|Ohlins|PCIII|Voltomotos|Full Staintune exhaust|Tuned|
APRILIA SXV|WEAPON|Re-built engine|AKRAPOVIC Ti exhaust|AF 1 Air filter|Custom map.
Now I’m of to make a series of comments on the internet intended to promote interest and then complain about everyone quizzing me.
XR8_ash is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2013, 03:58 PM   #2
Shockworks
Default Re: Rear shock question.
Originally Posted by XR8_ash View Post
Guys,
When you use blocks to lower the car you move the diff closer to the bump stops and a shorter damper will only reduce the travel even further. As the lower shock mount is pretty much inside the wheel you may be limited to 1.5 inch block with a 18" wheel. We have not used blocks as a way to lower the rear of a ute but using a shorter shock is not the way to go mate if your going to do this mod.
Hope this helps.
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2013, 04:26 PM   #3
XR8_ash
XR8_ash's Avatar
Understand. Thanks for the info.
