BASS ON BOARD!
Anyone had problems with axle tramp on the 1/4 mile?
i had no spare or sub in the boot at the time. Im wondering if the extra weight would stop it? it stoped me for getting a 14 sec slip :( ![]()
Nothing interesting to put here. |
yea when my shokers were shagged i had some but replaced em and fine now.
Could be that otherwise got me beat |
BASS ON BOARD!
The suspension set up is only 7 or 8 months old. i think it could be a combination of not enough weight/to much pressure in the tyres and the way i dump the clutch
I used to get it real bad, then i changed my upper control arm bushes. All good now
Tramp can be caused by alot of things, bad shocks, bad bushes, geometry problems (pinion angle).
If it goes away with extra weight in the back, I'd look at the shocks first. They might be new but are they good quality? - John |
Tickford
soon as i put in the king springs superlows it went away
My dad had massive tramp in his mustang.
He put tramp rods, stiffer suspension, tuffer tail shaft, higher ratio lsd and nice tread and no more tramp.. what fixed it the most was the tramp rods. |
likes falcon's
ive found shockers to play a big part in this usually.
www.carhubsales.com.au |
its not a!
Stupid question, but what is axle tramp?
#10 | |||
Gunna girlie-man
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
likes falcon's
wen u give ya car some gas on take off and the *** bounces instead of putting that power down to the ground
Gunna girlie-man
oh, it doesnt sound too good for the shockers and springs
#13 | |||
Regards Alan FG GT in Lightning Strike 5th anniversary edition in manual 1 of 25 And an 2019 MD Mondeo Trend Wagon in Platinum White |
#14 | ||
BASS ON BOARD!
LOL buy a AU! lol
I have no trouble on the road, but i did have almost 50psi in the tyres (im lazy from morgan park) so i hope that (being the high psi) is the problem. I have Monroe GT Shocks with king springs
#15 | ||
its not a!
When im accelerating hard sometimes i get surging acceleration after changing first-second. Is that just me not making clean changes, or is that axle tramp?
#16 | |||
they call me Tibbo
#17 | |||
BASS ON BOARD!
axle tramp sounds like your tyres and diff is bouncing up and down making a horific noise almost like a bad stut stut stutter.
#18 | |||
its not a!
#19 | |||
beep beep
Nothing to see here, move along, move along... |
#20 | ||
I had old shocks and floged out upper control arm bushes and got tramp real bad. Lowered the car 45mm in the rear and it was almost completely gone, New koni shocks and bushes and all fixed now but i was suprised at once the lower control arm was level it almost totaly eliminated it even with bad shocks and worn bushes still.
RIP, EL series 1 XR8, Manual, 3.45 LSD, 347 Stroker, Big bore Pacemakers, and K&N. 180.2 rwKw Replacment, FG MK1 FPV GT-P, Manual, 5.4, Stock Standard everything. |
#21 | ||
Can't get enough of this.
Location: Standing on the driveway sobbing because I don't have a PINK ute anymore :0(
hmmm and I thought you said you liked the tramp?!
#22 | |||
Ich bin ein auslander
Growing old is compulsory, growing up is optional! |
#23 | ||
Stiffer shockers will cure your axel tramp Drew. When I bounced the back of your car they felt to soft... and lower the tire psi to 20 -25
