Old 30-12-2005, 11:47 PM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Serp Conversion
Im thinking of doing the serp conversion to my car since
* A/C needs to be reinstalled anywho
* 70amp Mitzi doesnt cut it, 110amp is needed for all the crap going into the car
* Power Steeringpump is crappy.
Now most stuff I need can be sourced from work I assume, but I need to know exactly what I need...
Alternator
Harmonic Balancer
Idler Pully?
A/C Compressor
Power Steering pump
Belt (Obviously)
EF Timing cover
Also I remember there being some issue with having to get a XH1 Tensioner?
Thanks
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 11:49 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
talk to Dave, he did it :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 30-12-2005, 11:52 PM   #3
InitialD
Low and Loud
InitialD's Avatar
oh Thanks for the Info, I never guessed. :
Old 30-12-2005, 11:55 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
so who better to talk to then someone who did it first hand? :P
Old 30-12-2005, 11:55 PM   #5
John_LS1
If you put your mind to it you can accomplish anything......
Old 30-12-2005, 11:58 PM   #6
InitialD
Low and Loud
InitialD's Avatar
Hey doc Brown, get back to the Delorian, marty needs to get back to 1955 to get the Sports almanac from Biff
Old 31-12-2005, 12:01 AM   #7
InitialD
Low and Loud
InitialD's Avatar
I like to get as much information in regards to this BEFORE I start doing it.
Ill check with you next time before I start a thread :P
Old 31-12-2005, 12:01 AM   #8
John_LS1
Originally Posted by InitialD
Hey doc Brown, get back to the Delorian Biaaatch
manual delorian!
Old 31-12-2005, 12:04 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
gee sorry mick, suggesting someone to talk to is a big no no now.
remind me not to reply to ur threads then
Old 31-12-2005, 12:05 AM   #10
Damo
88 miles per hour!!!
EA2BA did this conversion too, but from memory there was some issue where his car wouldn't start or something. :P
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 12:08 AM   #11
InitialD
Low and Loud
InitialD's Avatar
yes the motor wouldnt start. Not the outcome I was looking for.
If someone who has a list of what parts I will need it would be great
Old 31-12-2005, 12:11 AM   #12
spope
spope's Avatar
Talk to dellboy, he did it and then his car wouldn't start :P
Yes, I know I haven't done it yet, but you need -
Power steering pump + bracket
Alternator + bracket
A/C comp
Harmonic balancer - ef or el will fit, but if you get the el one there shouldn't be the extra gear for the crank sensor
Timing case is optional, you can always just whack a little notch in for the timing.
Belt (obviously)
If you want to keep your current manifold (ie, MPFI) you will need an XH tensioner. Dayco sell them.
If you switch to BBM, you'll need the EL a/c brackets and you can use an EL tensioner.
Hey, if you do it before I do, I'll come give you a hand, so we can see what breaks on your car first! :P
spope is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 12:14 AM   #13
InitialD
Low and Loud
InitialD's Avatar
Thanks steven, Just what I wanted to know.
I will be staying MPFI as BBM has no benifits in my car.
Old 31-12-2005, 06:00 AM   #14
NZ
NZ's Avatar
BBM is MPFI :alien2:
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 07:53 AM   #15
Racecraft
they call me Tibbo
Racecraft's Avatar
talk to OED666 also ,,he did it when he went to the AU engine.. There was some issue with the ED log manifold and the A/C compressor iirc
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 09:03 AM   #16
LUXO_8
windsor user
yep, this is why you use the XH1 Tensioner...
as they had the 4litre with ED manifold and serpentine belt....
also, i do recall SWOOPA having some isses with AU into Eseries around the ac compressor...
i cant recall what he ended up doing, i think he modified a bracket..?? someone correct me
Old 31-12-2005, 10:22 AM   #17
InitialD
Low and Loud
InitialD's Avatar
LOL Mr Smartypants I was refering EA/ED MPFI instead of EF/EL BBM :
Old 31-12-2005, 10:52 AM   #18
Gunns
Gunns's Avatar
That was the dizzy hitting the a/c bracket. Nothing a angle grinder didn't fix.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 10:53 AM   #19
LUXO_8
windsor user
thats right! i knew it was something around there
Old 31-12-2005, 02:02 PM   #20
ilsautomotive
Former E-Series Member
If you're using the XH tensioner (pre BBM), you will be using the XH belt as well. I bought an AU belt for mine and had to sell it and then buy an XH.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 02:22 PM   #21
dansedgli
dansedgli's Avatar
I think the best option would be to buy a complete EF or EL then swap everything over.
Hope this helps.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 05:57 PM   #22
Bobman
Regulator
Bobman's Avatar
XH belt is about $30
You can use an EA or EB compressor if your happy to change the pulley ;)
Or you can just use a EF type one...
Also save some $$ and change the power steering pump pulley (very easy) instead of swapping pumps because you'll have problems with the hoses.
Everything is easy bolt on e.t.c, don't forget all brackets you'll need too, I did it on my EA and it was a fantastic mod.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 12:44 AM   #23
ebxr8240
Performance moderator
ebxr8240's Avatar
We have done it ... An AU engine into EDXR6...Lol....
Daily driver GTE FG..
Old 01-01-2006, 11:42 AM   #24
megsy
Undergraduate EB Operator
megsy's Avatar
what has to be done to the AC compressor, wrong pully? not in line with everything else? im considering doing this myself in the next month when i put thermos in
Simon
04 BA Xr6 ... now with carpark dints
megsy is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 02:23 PM   #25
Bobman
Regulator
Bobman's Avatar
You can either get a cheap dodgy EF compressor (as I did) and not hook up the lines, or change the pulley on your EA one which is not really hard just needs to be compressed out. The aircon lines are different IIRC, but you still use your EA plate, not sure what others done here but I went the dodgy way and had no air con
Regards
Bobby
Current Cars:
Previous Cars:
