Old 23-03-2007, 12:20 AM   #1
amiers
Default strange humming noise
have always had a bit of tyre/road noise in the Fairlane and recently had to replace the front wheel bearings. i do a lot of highway driving and the other day i didnt have the cd on flat out,as i do, and i drove for about 20 k's in silence. i noticed that the humming ,tyre noise?, goes away when i went over dips in the road!! as the suspension flattens the noise dies and when car is back up its back.
idea's please?
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2007, 12:28 AM   #2
JC
JC's Avatar
Wind tray under the front of the car???
Ford Performance Club ACT
Old 23-03-2007, 12:36 AM   #3
ronwest
All Bran = Regular Member
It may be that the extra weight on the tyres causes the hum to change/disappear (tread pattern flattens).
Old 06-07-2013, 04:45 PM   #4
champ
champ's Avatar
Default Re: strange humming noise
Me too! I've got this constant humming!!! Driving me insane. Have just put brand new Michelin tyres on, been told its not a bearing, but there is play in front calipers. Could this produce this noise? I've been driving fairlanes for over 20 years and have never had this! Any suggestions pls?
champ is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2013, 08:18 PM   #5
revcore
revcore's Avatar
I had the same thing in my old EL Fairmont wagon...Turned out to be uneven wear in the front tyres.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2013, 11:14 PM   #6
peterljohnson55
peterljohnson55's Avatar
Are you sure the humming is coming from the front lower? One side more than the other? I ask because the humming I had in front was the rear-view mirror on windscreen. It was a very slight loose fit to the bracket.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2013, 03:48 PM   #7
champ
champ's Avatar
Don't know... Have totally given up by now. Am due to go & get the calipers done in a couple of days, will see what they say about the humming noise. They told me it was tyres, which yes, admittely, it has lessened but it is STILL THERE!! Almost gave away my car for another 2 weeks ago because of this! So glad i didn't though.
Old 08-07-2013, 07:05 AM   #8
peterljohnson55
I suggest you ask someone to drive it for you on a long, straight and uniform stretch, and at a uniform speed, while you sit in the other seats front and back, with your eyes shut to try and pinpoint the direction from which the noise is coming. Do it again using two other speeds. Also, try it on different road surfaces.
Take your time when you do this - will need some concentration too, and hopefully you will pinpoint the location problem.
Old 08-07-2013, 09:06 AM   #9
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
What psi are you running in your tyres? Check your pressures on the off chance one is slightly deflated than the others. Worth a try & free!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2013, 07:24 PM   #10
champ
champ's Avatar
Thanks for the suggestions people. Tyres have 36 psi. They are 235/45/17 97w. Don't know....tonight on the way home it actually sounded like its coming from the back and it was actually louder with a slight vibration through the steering & the car actually felt like it was dragging.
Old 09-07-2013, 10:02 AM   #11
peterljohnson55
Hmmmm . could be diff
Old 09-07-2013, 10:31 AM   #12
champ
champ's Avatar
You think???
Old 09-07-2013, 10:45 AM   #13
peterljohnson55
Yeah I do Champ, could also be wheel bearings ...
but, for your car, what do you think?
Old 09-07-2013, 01:33 PM   #14
champ
champ's Avatar
Well.... guess what....hub/wheel bearings. One front & one rear. Booked it in to get them done next week. Yay! no more noise... But you are absoloutely right! No-one knows your car like you.... Tyre noise! What a load of crap!
Old 09-07-2013, 04:11 PM   #15
mik
mik's Avatar
tyre noise can doit, and especially if one is getting ready to delaminate, don't ask me how i know that :(.
Old 09-07-2013, 09:11 PM   #16
champ
champ's Avatar
Ummm stupid question but what is delaminates.
Old 10-07-2013, 11:52 AM   #17
mik
mik's Avatar
not a stupid question , the best description i can come up with is the tyre is made up of parts, the main part a large sheet of rubber moulded to shape that holds the air, these days most tyres have steel belt/s reinforcing , and the main tread area moulded over the top, in certain circumstances the main tread can come astray from the rest of the tyre, in some cases the steel belt will come away with the tread, or the other way around, lots of reasons for this, old age, abuse of the tyre, over heating ,lack of inflation, poor manufacturing, air getting between the layers due to a puncture repair and forcing them apart.
sometimes it will start with a slight bubble or deformation of the tyre, in the tread area, in the worst case scenario the tread can come off and the tyre blow, they don't always blow, sometimes they just lose bits of the tread/belt and stay inflated, i had one let go at 110 kph during an overtaking manoeuvre with about 4 foot of steel belt whipping around under the front guard(very exciting in a bad way).
Old 11-07-2013, 12:38 AM   #18
peterljohnson55
Examples of delamination here
http://www.intechopen.com/source/htm...ia/image13.png
and here
http://www.d2au.com/index.php?topic=353.0
Old 11-07-2013, 05:45 AM   #19
champ
champ's Avatar
Wow! I must admit ive been pretty lucky. Havent ever come close to anything like that. But then again im a bit of a princess with my car.....we are connected at the hip you see so for every little noise, off i go and get it sorted. Gotta love a quiet cushy fairlane.....hehe
Old 11-07-2013, 08:16 PM   #20
Can also sometime bedirt and grime on the splines on the drive shaft where it goes into the trans. An easy test is to give it (the front splined end) a soak with CRC or WD40 and see it temporarily goes away. The long wheel base cars are prone to this issue and dips in the road etc change the drive shaft angle change slightly and can make the noise change or go away.
Old 12-07-2013, 07:56 PM   #21
champ
champ's Avatar
Hmmmmm...... Interesting. Now someone else tells me it could be diff bearings?????? Don't know...will wait & see what my mechanic man Davo says.
Old 16-07-2013, 08:08 PM   #22
champ
champ's Avatar
Hello people, I'm back.... the humming noise?? Well I've got everyone "guessing" wheel bearings from 2 ford dealerships to a private mechanic who says could be "diff bearings". Tonight, on the way home we have developments... have started having a "clunk" every time the car goes over a bump or a dip as well as the motor doing a shudder when I come to a complete sudden stop. I am so over this, I should just get the sledge hammer & fix it properly & then just buy a new car! We shall see.... Chapter 2 after Friday when Davo has a proper look! stay tuned. he he
Old 16-07-2013, 08:22 PM   #23
mik
mik's Avatar
sounds like you just need someone that can diagnose it definitively for you.
Old 16-07-2013, 08:49 PM   #24
champ
champ's Avatar
I rekon. Times like this I wish I did what I wanted... which was to be a mechanic but there were no girl mechanics in the 80s... well not too many. Davo knows his stuff, but he's so hard to get in... Good mechanic, too many customers story. Never mind, will deal with the truckster for a couple of days...
Old 19-07-2013, 06:06 AM   #25
champ
champ's Avatar
Update everyone!!!! Had the wheel bearings done, all four mind you.... Idler pulley, some belts & stuff, and now silence of the lambs. Yay!!!!
