Old 09-08-2013, 08:57 PM   #1
DaveTE
Back in black
DaveTE's Avatar
Red face New seat belts stuck locked
Arrrh! I got 2nd hand rear seatbelts to replace mine in the XR8 which are shot(Spring coils gone). On removal these new ones were fine and working in the don or car. Now the two side ones are stuck locked. I can see the coiled springs are fine but they are locked tight and wont let any belt out. How do I reset them to let the belt out?
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2013, 09:03 PM   #2
Dman83
Dman83's Avatar
Are you new ones installed in the car yet? When I changed mine over they wouldn't work when they were out of the car but were fine when I put them in. Don't know how that worked but it did. Hope it helps
Dman83 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2013, 09:06 PM   #3
DaveTE
Back in black
DaveTE's Avatar
Default Re: New seat belts stuck locked
Yeah I wondered I they dont like being tipped upside down and the likes. I think the ball bearing must lock it when moved around but just wanted confirmation. Thanks mate.
______________
_.__ /________...\
_.._(___\\___//___)
Old 10-08-2013, 01:31 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
The ball bearing does activate the locking piece, hold them at the same angle as in the car and they should gently spool out.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 09:18 AM   #5
DaveTE
Back in black
DaveTE's Avatar
All good fellas. Exactly as above. XR8 ha belts now. What a complex device(retractor). The retractor needs to be on the exact angle of where it's mounted in the car to operate(to loosen). There's a ball bearing within it that works like a switch. I thinks it's designed that way for roll over accidents and it locks the belt in place. When mounted in place the mechanism released the belt and all good. I'm now an expert in rear seat belt fitting
______________
_.__ /________...\
_.._(___\\___//___)
Old 12-08-2013, 09:04 PM   #6
Jastel
You only need to alter the angle very slighty - eg turning, accelerating braking and they should lock.
Old 13-08-2013, 04:57 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
Easy, go and buy NEW ones like you should have done in the first place.
They're not that expensive...especially if bump into something and the Ambos cant get you out as the seat belt is jammed !!
Old 13-08-2013, 05:17 PM   #8
rmack
rmack's Avatar
New or Old the problem will remain the same. The belt must be on the right angle to get it to work.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2013, 03:12 PM   #9
DaveTE
Back in black
DaveTE's Avatar
Wink Re: New seat belts stuck locked
Having seen ambos work mate, they cut the belt so no dramas there. Seat Belts I got were in immaculate condition and the only reason that they have been fitted.
______________
_.__ /________...\
_.._(___\\___//___)
Old 15-08-2013, 01:34 PM   #10
Hords
Treasure your balls?
Hords's Avatar
Near on $200 for a new driver position one is not real cheap either. Maybe you're comparing them to truck ones.
Having a giggle at your recent predicament Dave as I was in the same situation when I took the above mentioned new one out of the box.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2013, 07:17 PM   #11
DaveTE
Back in black
DaveTE's Avatar
Talking Re: New seat belts stuck locked
Good to see you back in the Forums mate. Haven't see you for a while.
______________
_.__ /________...\
_.._(___\\___//___)
