DFDFDF
Hey Guys,
I am in a little pickle with my current project.. Quick run down is i am planning on running a full AU XR8 setup in my ED falcon sedan.. Have fully stripped the ED down and am now upto the point where I need some assistance with what loom I should run.. From what I can tell so far there is 4 main looms in an AU, Body, Dash, Drivers Side Engine Bay, and Passenger Side Engine Bay.. What I have: AU1 Fairmont Ghia Loom - Body and both engine bay looms AU2 Fairlane Loom - Body and Drivers Side Engine Bay looms AU2 XR8 UTE - Both Engine bay looms and Dash loom.. Motor is 200kw AU2 XR8 out of the ute.. Will be putting a XR8 T5 behind it.. ECU is a 12QB.. BEM is Pink.. Ignition is out of the ute aswell.. I will be running a quarter horse to bypass smartlock/smartshield.. I have re-wired my ED dash with the AU XR8 UTE Dash loom including AU cluster.. So right now I sit here and have been going over the various looms, and each of them seems to have very slight differences to each other.. Just wondering if anyone can offer advice in what combination I should put together that should work.. I dont mind snipping a few wires and bit but was hoping to try to keep everything as stock as possible at the start.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
DFDFDF
Anyone got a pdf version of the AU wiring diagrams, connectors and overall layouts the same as what is in the technical section they could email me?
Cheers, Nik
Lacking Imagination
COntact Russellw,
he was very helpful when I required a Diagram for the engine bay.
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
