14-01-2006, 12:41 PM | #1 | ||
well just got my box(eb2)
i went to the wrecker to sus some parts they told me the eb clutch pedals will fit but something about the handbrake cos its on the dash but he said it still will fit he told me the tailshafts are differant the yoks are not the same he told me the auto computer can be used but the idle will be affected so pritty much i have to get clutch/flywheel,clutch cable,computor,pedals,tailshaft is there anythink ive left out as for the centre console part im just ganna make somethink up as i doubt ill find one p.s if anyone has any of these parts and wants to sell em let me no cheers
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
14-01-2006, 01:19 PM | #2 | |||
Ford sell the center console parts
Use your auto tailshaft - its the same as the manual non-ef/el pedal boxes need modification fto fit up to the EF/EL steering column
14-01-2006, 01:29 PM | #3 | ||
ok thanks od u no roughfly what they charge for the console also what kind mods to the pedals to fit?
14-01-2006, 01:33 PM | #4 | |||
can remember what they charge for the console parts. Its only really the boot you need - somewhere around $20-30 from memory.
The pedal box needs some slots cut, threads removed and holes enlarged. Takes about 5 minutes with an angle grinder and drill. Ive got some pics, Ill see if I can dig them up. If you put the auto EF and manual ea-ed next to each other its easy to see what needs to be done.
14-01-2006, 01:41 PM | #5 | ||
cheers mate
15-01-2006, 04:12 PM | #6 | ||
so is that all i really need to know, is what the wrecker said about the ecu true?
15-01-2006, 04:17 PM | #7 | |||
Auto computers will work, but need to be tricked into thinking the manual is still there and even still they are not quite the same. Best bet is to get a manual ECU and avoid the headaches.
15-01-2006, 04:22 PM | #8 | |||
Here are the pics of the pedal boxs
The area circled in red is the part that connects to the steering column that needs to be modified. Also not the area circled in blue is used to mount some of the electronics in EF's. Early e-series boxes dont have this mount. this is the modification that lets the ED box get bolted in (ugly i know but it works)
15-01-2006, 09:05 PM | #9 | ||
ok cheers for that mate is there much differance in price between a eb and ef one? are eb ones the same as ea?
