Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 14-12-2013, 10:12 AM   #1
LPGUTE
LPGUTE's Avatar
Default Rear brake hose for Au Falcon with 328mm BF caliper
Hi matt, my stock hoses are rubbing with the upper control arm, is there a hose that will retrofit?
Here the photo of the current hose
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2013, 09:19 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Rear brake hose for Au Falcon with 328mm BF caliper
I can custom make some for you and we can change the direction.$180 for a pair of rear custom braided hoses.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2013, 10:26 AM   #3
LPGUTE
LPGUTE's Avatar
Will u need the car for a couple of days?
Sent from my GT-I9100T using Tapatalk
Many Thanks
High series bonnet
K&N Air Filter
BAXR6T Snorkle
Old 16-12-2013, 11:15 AM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
If you want them fitted we would have the car here for just 2 hrs at the most but i would have to charge you for fitting and fluid. If the fronts are rubber i would suggest doing them in braided as well. Sorry i don't make rubber lines here and can't quote on them asa supply only because they would need to be custom made. If the hose hasn't rubbed through the line i would suggest you put some heater hose over the rubber hose to help protect it.You can slice the hose and then fit it over.
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-12-2013, 01:25 PM   #5
LPGUTE
LPGUTE's Avatar
If u don't need the car to mock it up then I can fit it myself. Will I be able to pay and pick it up on saturday if possible
Many Thanks
High series bonnet
K&N Air Filter
BAXR6T Snorkle
Old 16-12-2013, 02:47 PM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I do need the car to mock it up so bring it down Saturday morning but on the other hand if we are to fit them it would be extra for the labour and also more accurate as i can check for clearances as we fit them.
MATTHEW PEARCE
Phone 02 9609 1101
