23-03-2014, 03:18 AM | #1 | ||
XR6T BA 2002
Hey i just need some help
Both my low beams have stopped working High beams still work though Switched over the green relay in location 9 with relay 11 Still nothing checked all fuses and wiring still looks good Any more suggestions if so please can you help Thank you so much
XR6T 2002 BA
23-03-2014, 08:12 AM | #2 | ||
When in doubt, GAS IT!!
Have you tried actually changing the globes?
A quick check of the circuit is to swap the plugs over on the lights themselves. As both low and high are H7 just put the low beam plugs on the high beam globes and turn them on to see if they work. Then you'll know for sure if it's the globes or the circuit.
26-03-2014, 08:26 AM | #3 | ||
XR6T BA 2002
Thank you so much for the reply and your help
Seemed both bulbs blew at the same time All fixed now Could find why both went like that
XR6T 2002 BA
26-03-2014, 05:57 PM | #4 | ||
I dare say they didn't both blow together but probably within a few days of each other. If you put a pair of globes in of reasonable quality then you can be pretty sure the QC is reliable so it has to be expected that both globes will come to the end of their natural life at roughly the same time. When I blow one globe I usually go and buy a fresh pair and the remaining globe that still works goes in the glove box as an emergency spare.
Bushbasher
26-03-2014, 08:41 PM | #5 | ||
XR6T BA 2002
Thanks again
Much appreciated your spot on having some spare in the glove box Definitely would save the high beam drive home again Cheers
XR6T 2002 BA
