my BF ute has a custom box on and when changing the rear tyres has to be jacked from front spring mount,, but if I had a flat tyre on the road the sizzor jack or even a bottle jack wont fit in there so Iam thinkibg a 4WD type exhaust jack and then a axle stand..... opinions please.
When in doubt, GAS IT!!
They are brilliant for getting a vehicle up off the ground but you just need to be careful of the surface you put them on as they are pretty much a big a$$ balloon and any sharp object can potentially kill the bag.
I think a 4wd jack would be better and cheaper.
Performance moderator
![]() Join Date: Feb 2005
Depends on area ?? Used exh jack with hay bails loaded.. No problem just DONT get under neath and use stands on front tyres .. Best on level ground ..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
check out 4WD forums most guys can these as no where to safely lift your modern ute with these.
ebxr8240Re: Exhaust bag jacks Depends on area ?? Used exh jack with hay bails loaded.. No problem just DONT get under neath and use stands on front tyres .. Best on level ground .. I never get under a vehicle for ANY reason
