Old 22-05-2014, 03:05 PM   #1
leonbray
Cougar Owner
leonbray's Avatar
Default Coolant moving around in expansion bottle
Just noticed that the coolant is bouncing about in the expansion bottle chamber above the main hose.
When the revs change as the a/c compressor cuts in and out it sends a spurt of coolant into the bottle.
It doesn't look like bubbles from a head gasket and the engine is running OK and not using any coolant
Is this normal or the signs of a head gasket problem
Leon
AUIII XLS with Tickford bits, 1968 XR7 (302W 4v roller cam), 1969 Convertible (302W),
leonbray is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2014, 03:36 PM   #2
Default Re: Coolant moving around in expansion bottle
Not normal but check for soft/ collapsing radiator hoses and try a new pressure cap first.
Old 23-05-2014, 09:54 AM   #3
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
I have had the same problem. Change of radiator cap and thermostat corrected the issue.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 23-05-2014, 05:42 PM   #4
Davehoos
Stu
coolant doesn't move until the thermostat opens-it its open when cold it needs to be replaced-it should not move too much when first started.
Then
clamp off the hose from the thermostat to the bottle-the radiator may need clogged.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
