Old 14-03-2011, 09:25 PM   #1
bartsau
bartsau's Avatar
Default Changing a clock spring?? How, do I need to?
Hi all,
I have a repairable write off in the form of a 1999 Series 1 AU ute. Story goes that it need a new steering rack and 'K' frame which I have done. However, in doing so I think I may have damaged the clock spring as the steering wheel binds up. It sounds like a wire with rubber insulator is being stretched. I have taken the wheel and Airbag off and there was nothing visible obstructing it. Put it back together and was good for about 10mins then same problem again.
I have a spare clock spring in a 2001 fairlane which I can swap over but I have no idea how to change the clock spring.
If someone could tell me how to change the clock spring that would be awesome.
Thanks, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2011, 09:45 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Disconnect battery and leave for 10
Remove airbag
Remove Steering wheel
then the clockspring is right infront of you... Just undo the 3 phillips head screws holding the wiperblade stalk in aswell, and just put it into the ute..
This way there is no easy way of damaging the clockspring (plus you get the fairy features)
Once you figure it out, its not that hard at all..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2011, 09:52 PM   #3
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Remove battery negative,and replace,just think that the clock spring is a string with wire in it,if you turn it all the way to the right it will stop turning to install it you have to turn it back 3 turns if you don't the wire will brake and never turn the steering when changing racks.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2011, 09:55 PM   #4
FGII-XR6
FGII-XR6's Avatar
there are 2 bolts at the back of the steering wheel to release the airbag ( being a series 1 it shouldn't have those horrible 5 point screws) you then need to remove the steering wheel undo the screws and the clock spring should just come off
[SIGPIC][/SIGPIC]
Rides:
Old 14-03-2011, 10:09 PM   #5
XRGhia
meh.
XRGhia's Avatar
my S1 AU Futura wagon has those shithouse 5-star keys..
really gets at me..
Old 14-03-2011, 11:00 PM   #6
bartsau
bartsau's Avatar
Sounds pretty straight forward then. I thought it was that but was not 100% sure. Should be easy as I have the tools for the stupid bloody 5star bolts for the airbag as I was sick of struggling with them all the time.
Thanks for the quick replies all.
Rhys
Wagon Build
Toy Car Build
Old 15-03-2011, 11:28 AM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
really gets at me..
They all have them. So what you do, is borrow a 5-key bit, take them out, cut a line with a hacksaw and then you can undo them with a flathead screwdriver.
That's what I did with my falcon!
Old 20-03-2011, 07:59 PM   #8
bartsau
bartsau's Avatar
Default Re: Changing a clock spring?? How, do I need to?
Well thanks heaps guys. Found some time this afternoon to swap the clockspring over. Only took about 20mins to do as well. The old one sure was stuffed that it for sure. The copper wire was actually starting to come out the side of the assembly.
Thanks again all, Rhys
Wagon Build
Toy Car Build
Old 11-03-2012, 11:37 AM   #9
timbobtimothy
I have a slight problem with steering wheel and this post seemed to get as close to the question,I want to replace the standard xr6Au 98' wheel as the leather is biodegrading every time I touch the thing.
I have a replacement wheel but it's not airbag-ed its a $380 wheel looks great, just want to use it in my 98' AUXR6HP not vct! if any one has done this conversion before please let me know.
timbobtimothy is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2012, 02:59 PM   #10
GK
Walking with God
GK's Avatar
Pretty sure it's illegal to use a non airbag steering wheel for a car that's previously had one.
I wouldn't do it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 11-03-2012, 03:49 PM   #11
SSD-85
GK
Correct. Illegal everywhere in Australia.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2012, 03:54 PM   #12
Stav
Smile
Stav's Avatar
Not only illegal but youll have the airbag light on all the time.
Old 18-09-2012, 09:57 PM   #13
horze
Hey guys.. im sorry to bring up an old thread.
Got my horn, cruise and airbag light on.. so 99.999999% clock spring issue... was just about to attempt when i saw the post saying turn all the way left and 3 turns back.. just wanna make sure (not exactly sure how the clock spring works so ignore my ignorance)
question is do i have to get the steering wheel and clock spring insync with each other.. so do i gotta have the wheels of the car perfectly straight so i get the exact mid point of the clock spring?
like i said.. might sound like a very dumb question.. i am mechanically minded.. but this one i got no idea how it works lol
thanx in advance fellas
p.s. im doing this for a ba xr6... its the same procedure right?
horze is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2012, 11:12 PM   #14
block58
block58's Avatar
To make it easier on yourself, center the steering wheel before you take it off (with the wheels facing forward of course), then follow the instructions on the clock spring which tell you how to center it.
If the clock spring isn't centered when you put it in, then you will snap its insides when you turn the steering wheel so its important to make sure its all synced together.
FG MkII G6 Ecoboost in Lightning Strike
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2014, 12:13 PM   #15
PJ.RAE
Can some one tell me how to centre a clock spring on a BA Fairlane
PJ.RAE is offline   Reply With Quote Multi-Quote with this Post
