Old 10-10-2014, 10:33 PM   #1
Andrej1
Default Ford Falcon BA XT ICC Problem
Yesterday i pulled out my ICC to get the DVD Player out and when i put it in back as it was i have a problem that the Screen is not turning on, some of the lights are on all the time like Oil Light, Petrol Light etc. and the RPM and Speed Arrow doesn't move, driving on blind speed...
How to fix this, HELP PLEASE!
Andrej1 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2014, 11:40 PM   #2
sideshow10
Default Re: Ford Falcon BA XT ICC Problem
I think u need to make sure the connectors on back which sit in the dash sit properly before u push the icc back in
is it all the way back in
sideshow10 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2014, 12:33 AM   #3
11ford11
remove ICC - pull white connector at rear towards you then refit ICC - if you dont reset like this,the connector usually won't engage properly when refitting ICC and you loose can bus or other circuits
dont tip ICC past 90 degrees as it can damage cd player
Old 11-10-2014, 07:54 PM   #4
sideshow10
hey 11ford11
ive heard not to tip the icc to far over
must be true
Old 12-10-2014, 12:24 AM   #5
auMatt
ORSM Ford Cruisers
auMatt's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Matt's valued contributions in the technical area associated with AU/BA/BF & Terri instrument clusters & ICC's is considered the authoritative guide to work by members in this are of expertise. His contributions stand alone in the forum in this technical
It will be the connector at the back not being reset before re installing. I have actually tested the upside theory. It will not affect a single disc ICC. I have a video of the ICC running whilst I tip the ICC in all directions. 6 disc stacker will be slightly different due to the Multi discs.
Matt
Sent from my iPad using Tapatalk HD
2004 Harvest Green XR6
Orsm Ford Cruisers
ORSM Ford Cruiser's Web Site
Contact me for all your Cluster Programming/Repairs & Window switch/ICC colour change for BA/BF/FG Falcons & Territory. Visit my SITE for info.
I Use and Recommend :
Ferntree Gully Auto Salvage
AutoWorks - Keilor
RIP Craig
RIP Samantha
auMatt is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2019, 07:08 PM   #6
potsyfromparkes
When you pull the ICC out make sure you reset the connector block on the firewall with a pair of pliers by grabbing hold of the connector and pulling towards you. You will hear it click in. If you still have problems you can guarantee that the only sure fix is to break the plastic around the firewall connector and pull it out as far as it will go. It will stretch a little bit. Thread a cable tie through each end of the connector block on the back of the ICC so you can get at them and then guide the ICC back in and reach over the back connect the electrical connector you removed from the firewall and do up the cable ties and then push the ICC back in fully and fasten with the screws. This a is guaranteed fix. I started having problems originally because my right front audio speaker was dropping in and out; I put up with that for 1.5 years before I had finally had enough.
potsyfromparkes is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2024, 12:07 AM   #7
arnast
Matt
The connector on the firewall has a black surround holding the connector in place i need to move the connector further back as the aftermarket stereo seems to be pushing against it if i remove the black surround to push the connector a bit back is there a risk of it falling behind the firewall?
arnast is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2024, 08:57 AM   #8
mad2
Regular...with metamusal
hi, it won't go thru the firewall as the heater/aircon unit is in the way. before you do that check the depth needed for the new unit against what actual room you have. and that connector has clips holding it in place, just undo clips on either end and it will push back slightly.
