Old 07-02-2006, 12:23 AM   #1
[chubbz]
Default Help removing head light
how are you guys well i was trying to remove the driver side head light and i undid all the bolts but it seems the one side wont come up over the barf any suggestions how i can get the dam light out thanks guys
[chubbz] is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 01:35 AM   #2
needfordspeed
How many did you undo? There's 4 all up for each light 2 on the top, one behind and there's one on right hand side if you look at it from the front (drivers side) but it's a bit tricky to get to, it's on the inside, kinda in the middle on the back (if that makes sense) Just have a look where I described and you'll get it.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 10:31 AM   #3
efgiar
rofl copter
efgiar's Avatar
theres 2 on top, 1 towards the middle of the car, and 1 behind the indicator and down a bit, what car are u working on? the ef/el is a @#%$ to get past the bar (sort of) u have to use a little bit of aggression to get it out
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 10:51 AM   #4
[chubbz]
its my on eb and i removed all four but still couldnt get it off
Old 07-02-2006, 04:25 PM   #5
Damo
you just gotta wriggle/force it out, try different angles etc. The drivers side one is allways a pain to remove.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 06:40 PM   #6
snypereb
[EBGLT]
snypereb's Avatar
Yeah definately give it a wriggle you have all the nuts out!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 09:37 PM   #7
5L
[ 5L ]
5L's Avatar
i just pulled my bar off, i tried for like 20 minutes to wiggle it out and got no where, i could almost get it if i pushed down on the bar, but in the end just took the bar off, its only 4 blots on the bumper support inderneath the car and the two white plastic twist things either side of the bumper then it just slides off.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
