Old 09-02-2006, 02:17 PM   #1
gozza
gozza's Avatar
Default Running Temps
My engine temp barely ever gets past the N...it usualy sits a few mm above the normal range starting point
is this too low?
is there any problems that can be cuased by this?
cheers
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2006, 03:49 PM   #2
Simmo
White Lightning
Simmo's Avatar
mine used to do that. i replaced the thermostat and now its in the O most of the time. if your car thinks its running cold it'll stay in the warmup loop and your performance/economy will suffer.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2006, 03:54 PM   #3
gozza
gozza's Avatar
see thats the thing...i thought myabe if the fuel isn't heated enough i might not be getting good combustion...i have no idea.....my economy is more than fine (9.8l/100)
may suss out the thermostat...also would me runnin an extra oil cooler have any impact on the engine temp
Old 09-02-2006, 04:00 PM   #4
Simmo
White Lightning
Simmo's Avatar
the temp gauge on the cluster is only a gauge of the water running though the system, not of the actual engine. an oil cooler is always good in a place like brisbane. can be bad in colder climates i've heard. a cool engine is a happy engine though.
Old 09-02-2006, 04:04 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Are you running an extra engine oil or trans oil cooler? Engine oil cooler would make a difference to the coolant temp.
If the car is running cold, the ECU will run rich, to act as a choke until the car gets hot.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
