Old 14-07-2015, 01:34 PM   #1
MeanstreakJR
. . T U R B O . .
MeanstreakJR's Avatar
Default Au Questions
Hey guys,
I have an au series 2 auto. I'm turning it into a burnout car
Getting turbo, huge cam etc, thing I wanna know is am I able to remove the ABS, or can I leave the ABS in and disable it?
Also I have removed the dash and will be making a custom dash, will the car still run with no acc's (head lights, indicators, etc) of course will will need smart lock
If anyone has turned one into a track car or speedway car running the au engine and Ecu.
BLUEPRINT BA XR6 UTE
MeanstreakJR is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2015, 03:07 PM   #2
xr8 007
xr8 007's Avatar
Default Re: Au Questions
With the abs, cant you just remove the fuse?
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2015, 08:51 PM   #3
MeanstreakJR
. . T U R B O . .
Will the car go into limp mode? Etc? My BA did :/
Old 14-07-2015, 09:50 PM   #4
xr8 007
xr8 007's Avatar
It shouldnt.
Old 14-07-2015, 10:12 PM   #5
bluestripes
Q - CAR
bluestripes's Avatar
go to the au build thread... as there is a couple of guys who are running au as a track car and have disabled the ABS and installed a custom dash.
it seemed very straight forward.
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2015, 09:19 PM   #6
MeanstreakJR
. . T U R B O . .
Cheers! Another question is to do with the BCM and smart shield, as it will be a track car I wanna get rid of the BCM... And all the junk I don't need what is involved? I want to have just ignition switch and a push button start I don't wanna have the key barrel etc
