Old 01-04-2012, 05:10 PM   #1
Ladiesman217
I can count to potato!
Ladiesman217's Avatar
Default 5spd Transmission Oil
Can someone tell me what oil to use, and how to change the oil in my AUIII XR8 5SPD ute please. Or a link somewhere that show how to do it.
Thanks.
W.
AU III XR8 UTE
Ladiesman217 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2012, 10:22 PM   #2
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Default Re: 5spd Transmission Oil
For the Borg Warner T5 - 4L of TQ95 automatic transmission oil plus 500mL Transmax-Z manual gearbox additive.
Drain the old oil through the bung on the bottom of the gearbox, refit it, and then pump the new oil in through the bung plug halfway up the driver's side until it overflows. Done
You can use a $20 oil pump from Supercrap etc, or a funnel, a mate, and a length of garden hose.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2012, 10:37 PM   #3
BHDOGS
what additive is good for the auto btrs?
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2012, 10:40 PM   #4
Day-mow
rexnet
Day-mow's Avatar
im using Transmax Z. no addative. it goes alright.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2012, 09:34 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Thanks.
W.
Transmax Z, you need about 2L or so from memory and a small hand pump will do the job. On the driver's side of the gearbox you will see 2 plugs that have allen key heads on them, undo the bottom one to drain and then refit, and undo the top one to refill. Check your capacity as it won't reach the hole before it is full so don't use that as your reference point.
Easy job to do but make sure you use the right oil first time.
2024 F150 XLT
Old 03-04-2012, 12:49 AM   #6
Ladiesman217
Cool, thanks fella's.
AU III XR8 UTE
Old 03-04-2012, 04:16 AM   #7
Venomous1
5.0 means business
Venomous1's Avatar
Got Transmax Z in mine for over a year now smooth as silk.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2015, 10:34 AM   #8
meanfalcon
Whats wrong with the factory spec Dex II and lubzoil additive.?
AU I LTD V8 Sleeper
AU II XR8 220kw SVO zorst, G&D Auto
meanfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2015, 07:46 AM   #9
madmelon
Best not to use TQ95 in the T5 gearbox. Use only Dex III or equivalent (Transmax Z etc) if you're going to use ATF. For extended gear life in more heavily loaded circumstances, use a manual gear oil as recommended on most oil companies websites. Manual gear oil will slightly increase shift times.
TQ95 uses friction modifiers which will negatively affect the synchro behaviour- shifts will take even longer than if using gear oil and you'll see no gear life benefits.
I discussed this with my engineering manager just a couple of weeks ago for my XR8. He was an engineering manager at BTR when they specced these T5 boxes for the AU and recommended to Ford they use manual gear oil.
madmelon is offline   Reply With Quote Multi-Quote with this Post
