Old 10-10-2012, 08:09 PM   #31
KR1STO
Just another mock-up..
KR1STO's Avatar
Default Re: Stall convertors ...
Awesome..!!
How much did they end up stinging you for it..?
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2012, 08:28 PM   #32
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Nice. What stall did you order? Be sure to remove the tranny cooling from the radiator when you install a decent cooler.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2012, 10:08 PM   #33
BZINGA
Powered by Ford
BZINGA's Avatar
Originally Posted by KR1STO
Awesome..!!
It was $1050 + gst
Stu
I ended up with the 9.5" 3k size. Yeah i'll make sure everythings done properly
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2012, 10:18 PM   #34
BZINGA
Powered by Ford
BZINGA's Avatar
Bit of an update ...
Spoke to someone at PWR via email and they recommended using the PWO6115 p/n trans cooler. Apparently made for the BA with the auto troubles they were having. The kit is boxed and ready to bolt on straight away, no mods needed which is good. So i have that sitting here atm.
Converter was ordered last wednesday and haven't heard back from TCE yet but hoping sometime next week i'll have it.
Also i've organised for the ute to get the converter put in etc when it arrives so hopefully not long now.
Old 19-10-2012, 08:16 AM   #35
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Just looked it up. Nice and big. Should be more than adequate!
Stu
2002 AU II LTD
Old 19-10-2012, 05:59 PM   #36
BZINGA
Powered by Ford
BZINGA's Avatar
Stu
Thanks Stu, yeah should do the job
Old 08-11-2012, 04:33 PM   #37
BZINGA
Powered by Ford
BZINGA's Avatar
Received the convertor last friday and with the short week because of the cup, earliest i can get the ute done is this coming wednesday so looking forward to the finished result
Old 17-11-2012, 12:29 AM   #38
BZINGA
Powered by Ford
BZINGA's Avatar
Ok for starters that pwr kit does not suit the AU .. not sure what the guy from pwr was on about .. brackets do not suit the AU. Trans cooler is fine though. Convertor is in and makes a big difference ... now thinking about diff gears
Not sure why i wanna keep spending money on this thing, i keep thinking about selling it and getting something old school ...
Anyway the convertor makes a big difference and adding gears would be even better ...
Old 17-11-2012, 07:29 PM   #39
BHDOGS
so the 3grand converter transforms it? ive thought about it to add to my 3.9 diff gears.
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2012, 07:20 PM   #40
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Stu
Bypassing the radiator has a few draw back regarding temp control and bring the transmission fluid up to operating temp if the cooler is in free flowing air.
Also the lack of air flow in heavy traffic will cause excessive heat build up as the radiator cooler has the benefit of the fans, depending on the location of the external cooler the fans effect is some what diminished.
You could consider just upgrading the radiator to full alloy side tanks and running the radiator inline with the external cooler.
Or
Running a thermostat controlled fan attached to the front of the external cooler and set the external cooler up in a non free flowing air spot.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2012, 07:26 PM   #41
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Eliminating the radiator is a 100% sure way of not filling your auto trans with water. The rest of the arguements are - errrr very manageable.
2002 AU II LTD
Old 18-11-2012, 07:51 PM   #42
Giant
Giant's Avatar
Yep I get the reason for Air to Oil cooling and yes the temp control is manageable but is often over looked. Most of the fitting Kits are for in front of the radiator in free flowing air and a air gap between the radiator.
Oil and the transmissions works best when its within its correct operating temperature range.
No need for the condescending head slap smiley.
Old 19-11-2012, 06:21 PM   #43
BZINGA
Powered by Ford
BZINGA's Avatar
Yeah very noticeable difference in take off .. even with the standard 3.45 gears it want's to giddy up nicely. If you have the spare cash for this upgrade then do it, you'll love it.
Old 13-08-2015, 07:42 PM   #44
NCII40
XR6T BA 2002
NCII40's Avatar
Installing my HiStall this Saturday
TCI 2500 - 2800RPM
Anyone had to add or even heard of this module??
Any heads up before doing this so i don't get stuck?
XR6T 2002 BA
Old 16-08-2015, 12:06 AM   #45
NCII40
XR6T BA 2002
NCII40's Avatar
Stall in
Smashed it
3 hours with some professional help ** needed **
Wedged the box between the extractors to drop it just have a few big screwdrivers handy
Now i notice little difference on take off or full throttle??
More noticeable climbing from about 40ks up to 80ks? slips and revs up to about 4k
certainly an improvement that area
Is this how they work?
XR6T 2002 BA
Old 11-09-2015, 02:28 PM   #46
mcfly94
mcfly94's Avatar
stall converter is to engage the driveline when the engine starts making its power otherwise it will be laggy below the rpm the cam makes power, for instance your cam starts making power at 3k, but only have stock stall, will be a dog till it hits the 3k+
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2015, 02:29 PM   #47
mcfly94
mcfly94's Avatar
ideally stall size is done after I think max torque and rpm level is known
Old 11-09-2015, 06:03 PM   #48
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks for the reply man
Certainly more noticeable now, since the install. bottom end lag completely gone drives way better
Fuel consumption sky rocketed, last fill was 47 liters @ 257ks. Worth it though
XR6T 2002 BA
